Thank you, they seem a very good quality and look real. What company made them?
**VIEW THREAD HERE** |
No manufacturer information. Sold here: https://www.shipmodeling.ru/shop/model_elements/rangout_takelaj/shkivi/Thank you, they seem a very good quality and look real. What company made them?
Есть желание самому делать коуши, но не знаю как. На Меркурии я тупо нарезал трубки латунные, но это не то.No manufacturer information. Sold here: https://www.shipmodeling.ru/shop/model_elements/rangout_takelaj/shkivi
The simplest and most time-consuming. IMHOP is to use a lathe. Olga @shipphotographer.com knows one method using the drawplate. I hope one day she will share with us.Есть желание самому делать коуши, но не знаю как. На Меркурии я тупо нарезал трубки латунные, но это не то.
Пару лет назад она на своем Ютюб канале выкладывала видео изготовления коушей. Как то пытался найти, не нашел.The simplest and most time-consuming. IMHOP is to use a lathe. Olga @shipphotographer.com knows one method using the drawplate. I hope one day she will share with us.![]()
as usual perfect. I have no further words to use, as i have used all. well done-Setting the standard, Sasha, very nice shroud and ratline work.
again the translation is not clear to me, what did you mean?I hope that you have the first through seised from top to bottom
Thanks, PaulAlways impressed with your work Sasha! Precision everywhere I look.
Ha! Sometimes accuracy and patience IS complicated!Thanks, Paul
In fact, nothing complicated, just accuracy and patience.
And yes - I like it
...said by a very accurate and patient friend of mine!!Ha! Sometimes accuracy and patience IS complicated!
they can be used at 1:70 aprox. I learned to spice A BOY IN THE FISHING HABOUR IN DENMARKThanks, El Capi. My interest was in methods making eye splices in small scale models as 1:84.
My fault this time - too much in a hurry - it is a misspelling. it should have been SHROUD. This 1Th SHROUD was seised from top to bottom, protection -as it came in contact with the lower Main Sailsagain the translation is not clear to me, what did you mean?
Are you talking about the front shroud? Yes, she's covered from top to bottomMy fault this time - too much in a hurry - it is a misspelling. it should have been SHROUD. This 1Th SHROUD was seised from top to bottom, protection -as it came in contact with the lower Main Sails
CORRECT-I will be away for some days as my wife will have to be operated on for a minor tumour behind her right eye- which she nearly got blind, but the crew in the hospital -injected something directly into her eye, once a month and has now recovered 80 % about- there may be a connection between the tumour and the eyes. we shall know next Thursday the 14 dic, so a happy Christmas this year. never are Razer sharpAre you talking about the front shroud? Yes, she's covered from top to bottom
