- Jun 13, 2022
Thanks Mike, another thing to order so I can experimentThis is what I did:
To begin with I applied a layer of Occre varnish. After that I covered the deck with Judea bitumen and wiped it of after about ten seconds. What happens is that the bitumen remains only in the grooves of the wood, so it is not soaked up like when staining. If you want a stronger effect you can repeat, After that you will need another thin layer of varnish to fix the bitumen. Additionally you could of course stain with oak before varnishing, which I did not. A different varnish will give a different result. Do not sand between varnishing and applying the bitumen, because this will give an uneven result.
