How do you make a strop for a rigging block?
  • Thread starter Thread starter Y.T.
  • Watchers Watchers 9
Toronto, Canada
Hi. I am about to start rigging my Victory model at 1:90 scale. I need to put strops on hundreds of 3 mm tall blocks. My rope is 0.25 mm diameter. How do you imitate an end splice of a strop? I am specifically interested in how you butt join two thread ends together making a ring out of thread.
This has been driving me up a wall for almost a year. All the methods I've seen overlap the strop between the block and the loop. It's only overlapped for about 1/16" but I guess the serving and glue hold it together. It looks iffy to me but that seems to be how its done. A few links.
I guess that in real life a rope grommet is made to put round the block. web sites show how to make these. It would need a lot of patience to ceate them in quantity at 1:90 scale.
I think that to make a grommet they unwrapped a length of rope into it's three strands. Then they took one strand and kind of wrapped it around itself to recreate the rope in a loop. That's a crumby explanation. How about they took one strand, tied a half hitch in it, and then just kept sticking the ends through the loop until the rope was recreated. Not much better but maybe you can see it'
Yuri, just make a knot at the end of the block, tighten it tightly, drop a drop of CA on the knot and bite off the excess on both sides. Even Dmitry Shevelev does this on a small scale
I made this jig to help me. It has various clamps and clips to hold stuff. I clamp the back edge in the vise and the two arms give me room to get my hands around stuff. It allows me to make most rigging off the ship. Working rigging on the ship has proven very difficult for me. There is two spools of serving thread on the back edge. The thread leads through a hole so I can jam it tight so I can pull against it. The front left corner has removable pieces that fit different size blocks. The two alligator clips
on the wires are adjustable to tension the lines while I serve(or whatever) them.
I went by Alexander’s suggestion. Here is what I got. Looks not bad. But this is something like a fourth attempt. I must admit I hate working with threads and CA glue. I would rather do some wood work.
Yuri, then you need to switch to the Admiralty models, there are a minimum of threads and you can only get by with PVA glue
I agree. This must be considered after I finish Victory rigging (if ever). May be it is only from the start so repulsive and later I will start enjoying it? I mean it could be same as with starting drinking an alcohol or smoking. :)
Your time will shorten up. :) I too, am finding rigging to be tedious. I'm finding I have to research each piece of rigging for at least a day and then another day to make and attach it. In the end, though I think the rigging will make it more interesting to the "common folk"(family):) that will be looking at it.
I wound a thicker rope 0.34 mm diameter. Here is the result. But it takes me about 10 minutes per block! Isn’t it a bit too much?
I consider myself as bit lazy so that's why I'm trying to shorten the time on anything on my models...:cool:
When I have many pieces, I divide the work in stages, making each time the same thing on all ones.
So try this. Make 5 stroped blocks with Alexander’s suggestion and then 5 ones with mine.
Proceed to each method with stages. First make the loops on all 5 and the the seizing on all ones.
See with what worth the time.
Thx
