- Jun 17, 2021
Good evening. Good thinking and planning. She is looking wonderful. Cheers GrantI decided to go forward with raising the height of the bulwarks. The plans show that the bulwarks were supposed to by 9/16" in height. At scale the height would have been 4'5". As built, the height is 6/16" or 3'. This is why no one's guns fit anywhere near square in their ports. I decided to add 1/8", or 1 foot, to the bulwarks as a compromise. I made the decision based in part on art (how will it look once finished) and in part on a re-scaling of the guns and carriages. Keep in mind that the finished thickness of the bulwarks is 1/8".
Initially I thought to do the task with 1/8" square stock. Happily, I didn't have any! I have lots of 1/8 by 1/16 and decided to laminate. This was the right call because I had to edge bend to get the new wood to follow the curve of the bulwarks from the stem to just before the lovely curve of the stern. You might say that I could have avoided the edge bending by sitting the wood on it's 1/16 inch side and bending it as if I were planking the hull. I rejected that idea because, with the tools at my disposal, including clamps, I believed that I would do harm to the copper plates and perhaps the hull.
First I removed the 1/32" square material used as port stops from the fore and aft sides of each port.
My process was to soak the 1/8" x 1/16" wood in hot water and apply some heat from my electric plank bender. I then clamped and pinned the pieces to the hull and let them dry. For the first layer of new wood, I cut the lengths into sections I could easily work with - short enough so the combination of CA and wood glue would be workable without making a mess. The second layer was shaped using the same method, but I was able to lay it down in one piece because I now had a very even and completely clean surface of wood to attach to.
Photos - 1 Port lid stops being removed, 2 First six inchesof height is down and attached and second layer drying in place, 3 Bulwark height now at a scale 48 inches.View attachment 428726View attachment 428727View attachment 428728View attachment 428729
What BMThe safety of the crew is most important. It looks good and is very clean......looking forward to seeing the guns in place...
Thanks for looking in, Grant!Good evening. Good thinking and planning. She is looking wonderful. Cheers Grant
Thank you, Pete!What Grant said.
Thank you, Pete! When I heard the rudder snap I swear I could see your post warning me about the unintended consequencesWell done! I would not be so arrogant as to fault your tenacity, imagination and ingenuity (let alone courage) to embark on such an elegant, if radical solution to the seemingly endemic problem of a kit's guns being slightly over scale from the boat for which they were intended.![]()
Good morning, Paul and, thank you! There were times when I thought "holy crap what have I gotten myself into! Pete Gutterman warned me!" Last time I rejected a rather prescient warning was late June 1983, a Sunday right before I was to report to West Point. My dad said maybe it wasn't a good idea to play soft ball (I had been doing so for 4 weeks with a group of HS grads waiting for college AND there was a really pretty girl). I said don't worry, dad, I won't slide into any bases. Short of it: slide into third base trying to catch the pretty girl's eye, rolled over the bag, re-injured my already unstable knee, got to West Point and couldn't walk unaided after a couple of days of Beast Barracks. So instead of becoming a soldier, here I am. Changed my life. Happily, Pete's warning just echoed in my mind as the sanding dust got all over my paint job. Dust all over my copper plated hull. AND where I rested the hull on a tee shirt the tiny edges of the plates wanted to grab the fabric and pull up.Appears to be a raving success!
