Yuri's USS Bonhomme Richard - POF - Cross Section in Pear - 1:48
Very informative - many thanks for showing us the different ways - great
Thank you so much for the quick reply, the excellent pictures and description!
I turned some bolts on a metal lathe for my rudder pintals on Serapis, but they took forever! Your steps seem much easier (a bag of nails in an hour) make mass production possible! I will be giving this a shot as my build progresses.
Yuri,
I believe the ships carpenter may have cut a supply of wedges/chocks that the sailors hammered into place to stabilize the barrels. See photo below:
Your idea of the ships ballast being used to chock or secure the barrels may have also worked well!
The way you built the barrels, without the internal frame provided by the manufacturer, is amazing!!! Mine have the framework provided, inside each barrel.
Yuri,
Hi Brad,
Wedges will work fine in wine cellar without additional support. I'm thinking sailors would have to strap any cargo including barrels with ropes or net to prevent dislocation during rough sea.
I only made a few barrels without supplied internal framing. I'm thinking to have couple open barrels with the lid beside "freestanding" on the deck above...
Yuri
Hi Brad,
Yuri, I agree some barrels near the top would need some kind of lashing/ropes. I do think the wedges and ballast would keep the bottom barrels very secure. See comments in above photo.
I love this idea of open an open barrel, maybe one with a ladle for water (or rum ration)?
Take also a look at this topic with contemporary drawings of stowage
Hello everyone!
I just wanted to clarify that I didn't leave this kit. The year 2024 has been quite hectic for me due to some personal issues and complicated projects at work. Fortunately, everything is okay now, and I’m hopeful for a better 2025.
I wish everyone good health, happiness, and all the best in the New 2025 Year!
Now, let's move on to the next step on how I made the pumps, which involved mixing parts from the kit along with a few components built from scratch.
IMG_3235.JPGIMG_3237.JPGIMG_3239.JPGIMG_3265.JPGIMG_3269.JPGIMG_3272.JPGIMG_3273.JPGIMG_3274.JPGIMG_3275.JPG
Best,
Yuri
Those pumps are amazing! The additional detail and metal accents really bring them to a different level!!! Your attention to detail is superb and your photos to document the great work is awesome, even if your little guy is a little pale :p !
Thanks for sharing.
I decided not to use the mast from the kit because I was not satisfied with the quality of the wood and its light, almost white colour. Instead, I assembled six square planks and two flat planks to create what I believe is a better mast design. Here is what it looks like.
Best,
Yuri
Thank you all for your support! It has been over a year since I started working on this kit, and I have learned so much about shipbuilding. I'm trying to understand the "logic" behind ship construction rather than just following the kit instructions. I truly enjoy the process, so please bear with me regarding my slow progress if you are following my posts. I never realized the wide range of skills required for modelling—it's something I hadn't considered before I built my first longboat model, and now this one.
A special thanks to everyone who shares their work here in this forum and to the administrators running this knowledge base.
Best,
Yuri
