Very informative! I had no idea of the origin.You use the term ‘Start from Scratch’ to indicate that you’re beginning from the very start without previous preparation or advantage.
The term ‘start from scratch’ comes from the game of cricket, where strikers are admonished to keep their bats on the scratch line. The term was first seen in 1778.
Build a computer from scratch then look the expression up on Google.
So let us make kit-bashingI do not have time to grow my own lime and walnut trees. Cotton will not grow in the UK. I have no foundry with which to cast cannon and anchors. I cannot cut sheet veneers to make my own plywood. I am therefore dependant on kit manufacturers and their extensive supply chains to provide me with materials and fittings.
True scratch building is not an option for me.
Different kits can invoke various interpretations of the term bashing.I do kit bashing all the time..
bashing
noun
UK
/ˈbæʃ.ɪŋ/
1.
strong criticism of a particular type of person or thing:
2.
a physical attack on someone or something
3. mainly UK
the act of hitting something hard
This should be the contemporary definition of "scratch-building". There are so many cool parts out there, and people with a variety of technical skills all over the world, that it should be completely acceptable to use other people's skills in producing a unique model. I would include using other people's skills in CAD as acceptable material, as well.It can also mean using raw materials- boards from store shelf, metal from K&S, plastic from store shelf. You can also use small bought parts like PE and fittings like anchors, blocks, etc, as long as bulk of model is scratch. Pure scratch is you build everything, but purchasing small details is still scratch.
Cutting them out is not quite enough. It would be best if you made sure there were no worms or other live insects, it does require klin drying before you can use the wood for modeling.in a kit build you get a thousand pieces already pre formed for you, the attached picture is of the thousand pieces in a scratch build, you just need to cut them out
