- Oct 1, 2023
Here a link to my latest update: https://shipsofscale.com/sosforums/...e-1-48-scratch-build.13988/page-6#post-378692Could you share some photos.
Those maststeps; it took me ages to get them in the right spot; I think I quadruple checked the install and did it all over again.Mast steps assembled. Sister keelson curing.View attachment 449097View attachment 449100
Thanks for the photos. I feel a lot better after seeing them.Might be as good a time as any to form the tenon on the ends of your mast to fit the mortise formed into mast steps. If you wait too long it can become difficult to access.
View attachment 449143View attachment 449144View attachment 449145View attachment 449146
Thank you. I'll move it.You might check the main mast step location. It looks to be sitting on frame 28, where it should be frame 29.
If you look at Dan's pictures you'll notice there is one frame between frame 31 with the holes for the bilge pumps and the location of the mast step.
I don't know if I made it clear. The mast step is now aligned with the frame.Ok I was trying g to align the junction of parts 43 and 47 with the center of the back frame half.
Thank you got the clarification
Ted
After building the hull with the frames, then my build is on a lot of chapters ‘a bit out of the box’. It’s better to stay on the manual. Daniel and Johan can manage you better through the construction.I am so tempted to try installing the lower load bearing beams and cross members I loved in Peter's build but have decided not to attempt them. Having only hand tools and little experience it would be asking for frustration. In this case I'll just sit back and admire the work of others.
Ted
Can’t say my build is an exact “build-to-instructions” one. As far as the frames go, yes, but after that a lot of minor and major changes: ballast in the keel, sister keelsons, lowered focsle floor, added aft cabin floor, partial planking of lower decks, lighting, sails, adjusted rigging and the list goes on and on.After building the hull with the frames, then my build is on a lot of chapters ‘a bit out of the box’. It’s better to stay on the manual. Daniel and Johan can manage you better through the construction.
My excuses, Johan. But also to Daniel. For pointing yours and Daniel’s as build-to-instruction. That’s the problem when you start typing BN builds. Won’t do it again.Can’t say my build is an exact “build-to-instructions” one. As far as the frames go, yes, but after that a lot of minor and major changes: ballast in the keel, sister keelsons, lowered focsle floor, added aft cabin floor, partial planking of lower decks, lighting, sails, adjusted rigging and the list goes on and on.
That doesn’t mean I’m not willing to help…
