It’s a toss up for me between the light weathering and the heavy weathering with sanding. And since I’m just catching up to a question from a month ago, I can tell you went with the heavy weathering with sanding. Great choice. And given this is only your 2nd model, nice jump into the world of weathering.Hi all,
I need your help to decide how to go on with the deck.
From the left to the right right decks:
without weatering; light weatherig; heavy weathering with sanding; heavy weathering
View attachment 434329View attachment 434330
View attachment 434331View attachment 434332
I think every option is quite nice, but which one suits the buccaneer best in your opinion?
Good afternoon. All looking good. It takes a while and then loads of sanding and then we do it all over again…..reward worth it tho. Cheers GrantSome news after a longer time:
Planking finished for the upper part.
And now starting from below:
Especially the planking on the below part takes me a lot of time.
Hi Hugh,Planking is challenging but keep at it. Quick note… when I was done with mine (also the Buccaneer - and shameless plug, there’s a build log), I tapped all the nails in only to then realize that I’d have to file the nail heads away. What I should have done (after the glue was fully dry) is remove the nails.
Regardless of what you do, plan on spending time on the sanding and filler of this first planking. The better (smoother) it is, the easier the. 2nd planking will go on, and ultimately the better it will look.
But I’m no expert… I’ve only got 2 plankings behind me.
Hi neilm,Have you tried soaking the planks beforehand. There’s a lot of breaking there, instead of bending smoothly.
Hi Allan,You might enjoy and learn some good tips from the four videos from Chuck Passaro including the first one here for help in proper planking.In general it is a good idea to research all aspects of a model, be it scratch or kit. We are so lucky to have the resources at our finger tips today, why not take advantage of the opportunity.
I need an advice for my next build:
That's how the garboard plan should look like based on the document @Uwek shared with me. (I don't taper all the planks to correct with - I need room for improvement with the next ship- yes I know even without that there is much room for improvement)
That's how it looks at the moment on my ship (already after some corrections).
First I cutted the blue part awayto be able to glue the plank without much bending.
When trying to fit the second plank I realized that I also should(?) cut away also the red part (foto after removing the red part)
When I have a look into that document I think I'm already wrong, my first plank looks much more like the incorrect side. But I'm fine with it, because if I get my ship nearly as beautiful as @HughLo I'm more than happy.
To make it 'correct' I have to cut it like that - correct?
But how could I find a good/the correct radius?
