Modelship Dockyard - New Kit H.M.S. Enterprize 1774 1:48 version by Modelship Dockyard
Bonjour, pouvez vous préciser les dimensions d'encombrement (Long, larg, hauteur hors gréement) de ce projet ?
Hello, can you specify the overall dimensions (Long, width, height excluding rigging) of this project?
Great Development - and she is looking very good
Only one short advise:
The deck planking in the hold would not have any butt joints - the planks are short enogh, that all the planks would have the full length - only as a hint, how the planking in the later kit would be? if it is only strips, than every model can make it how he want - if laser cut or marked, it should be corrected -> no butt joint pattern in the hold or lower decks
Hi Uwek, Thank you for pointing out, that is indeed a error made by the modeller of ours. The kit will be supplying strips instead of full laser cutted deck, so that won't be a issue.
External planking. We are likely not be using the timber we are using on this model for wales, it will either be ebony or pearwood, but I highly doubt that the ebony of that thickness would be very hard to be bent, so more likely it will be pearwood.
View attachment 441853View attachment 441854View attachment 441855View attachment 441856View attachment 441857View attachment 441858View attachment 441859View attachment 441860
This looks a great kit. Just what l shall be looking for after my Granado kit is finished. Looks like l have found my next build. Looking forward to the release date
It looks like something went wrong over there... .
IMHO, a pity that beams and other parts are going to be sandwich-made. Perfect squared notches could have been milled on solid parts at 45 degrees, as D. Antscherl suggests in his monographs. A challenging effort, anyway.
Guess that is a decision of cost. These strips of the sandwich construction can be lasered instead of milled which is a big difference in cost.
