I had this machine (FF230) some years ago. The quality is very good in my opinion. I sold it because the motor runs to slow for wood and i had ugly results with it.
simply ingenious, I will try to replicate one! Thank you for the hint!This is a simple end stop I made some time a while specifically for the Proxxon MF70. The small design makes it suitable for other mini milling machines like Proxxon FF230 and the Emco Unimat series.
Thanks for the reply Jim. Come to me if you have any questions about the design and good luck with that!simply ingenious, I will try to replicate one! Thank you for the hint!
Sure I will, do you have any drafts by chance, I mean the measurements?Thanks for the reply Jim. Come to me if you have any questions about the design and good luck with that!
I have metric ones;Sure I will, do you have any drafts by chance, I mean the measurements?
Hallo @TrainGuyHello -
A brief intro - have new MF70 for model railroading (1:160) and joined this forum as the info on using this mill was difficult to find. I’m trying to figure out very simple steps such nomenclature, adjusting to max precision, setting up the vise, holding odd shaped work, end milling and precision drilling
My first simple ( well it seemed to me a first) project is drilling accurate holes for metal grab irons on the ends on a diesel locomotive ‘a short and long hoods. So holding styrene plastic, getting the exact spacing etc. Later will try milling alloy locomotive frame for speaker, decoder and wiring.
You all have a great supportive atmosphere I’m glad I’ve found this forum and specific thread. I’ll be reading and studying what this group has learned and freely shares.
And down the road I have a few waterline ships and boats to build for my 2 harbors (Whittier AK and Seward AK ) as well. A USCG cutter, sea going tug, rail barge, a very small container ship, a container crane, Alaska commercial fishing boats. The barge will be operational - that is have functional rails so and expected first project.
Probably common knowledge but news to me - https://www.usovo.de/en/search?q=Mf70. Far more than I want to spend or do but will keep it in the back of my mind as I learn the basics. Thought the dust extractor looks interesting. Shipping the Colorado is a bit prohibitive.
Liked the suggestions of “just do it” and I’ve started with a block of basswood and quickly found a small brush to keep the shavings away was essential. Milled two sides referencing the fixed face and was pleased to see 90 degrees and very smooth surfaces. Extremely basic but I needed to start somewhere.
Thank you allowing me to post and lurk and learn
Bob in Denver
Beside the Proxxon mill unusually used, I saw a mallet headI needed to clamp the keelson onto my Dutch ship, and I don't have a clamp that fits, so I used my Proxxon MF70 and it works perfect.![]()
Very firm. The ship is clamped in the vice and between the vice and the drill head. That will go nowhere. And by the way: The construction of the ship is very light but surprisingly also very strong. These Dutch builders know how to make a strong construction.How firm it sits on the kilson
Good looking item @£68 BUT! ---- a whopping great £!£% £135 shipping via UPS econ. charge.Here is the titling platform:
Look on Aliexpress, there is a similar product available for about 50 incl. Shipping.Good looking item @£68 BUT! ---- a whopping great £!£% £135 shipping via UPS econ. charge.
Obviously a 'no-go' here, but will make a future DIY project, methinks.
For me, the price is too high for something that would only have occasional use. I've probably got most of the material required to make one.![]()
조정 가능한 각도 조정 플랫폼 틸트 펀칭, 틸트 베이스, 목공 테이블 및 의자 다리 펀칭 - AliExpress 1420
Smarter Shopping, Better Living! Aliexpress.comvi.aliexpress.com
Price a little bit higher. 100 plus shipping, but I think when you search around there will be a store that is cheaper.
I don't bought it to, because to expensive/usage. There are simple solutions to achieve the same thing.For me, the price is too high for something that would only have occasional use. I've probably got most of the material required to make one.
