HI THAT IS ONE REASWON I DO NOT BY FROM THEM I GOT MINE FROM AMAZON  THE PRICE WASW AQBOUT THE SAME  DELIVERY FREE 2 DAYSW.   GOD BLESS STAY SAFE YOU AND YOURS DON
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
I couldn't find anything on Amazon UK.HI THAT IS ONE REASWON I DO NOT BY FROM THEM I GOT MINE FROM AMAZON THE PRICE WASW AQBOUT THE SAME DELIVERY FREE 2 DAYSW. GOD BLESS STAY SAFE YOU AND YOURS DON
Thanks Stephan. I agree with what you're saying, but I'm happy to keep the blade & to keep trying to get into the website again.Look if your order got a free return option, you can get your money back.
@donfarr Aliexpress is not bad to order, you only have to look good what you order. Especially when you use the app. The website is better to use.
Violin block1) Poulie de sus-vergue = bollock block ?
Control block2)Poulie de tournevire = voyal block?
It just shows that every language has its own peculiar names.Violin block
Control block
But I'm not 100% sure about this translation. Control block is in Dutch geleide blok or schildpadblok?
Good that your computer is working again.
Yep - a spare blade! After searching for 'ages' yesterday, & kept being sent to their Dutch site, where the cutter was not available, I tried again a search, after twice more into the Dutch site, I googled Aliexpress China & got there! Cutting station £43 ($54).Sorry to break bad news, but the price you saw is for the additional cutting pad. Look at the ad again and scroll through the pics…. You will note that the price changes with each pic….i guess they set the default pic to show the cutting mat and the $6 price which is misleading…….the cutter will cost you about $60
I know it has been a lot of effort to get there....but you will be glad when you finally get the cutter....it is well worth it. I use mine everyday and still love it.Yep - a spare blade! After searching for 'ages' yesterday, & kept being sent to their Dutch site, where the cutter was not available, I tried again a search, after twice more into the Dutch site, I googled Aliexpress China & got there! Cutting station £43 ($54).
'Ee by gum, that were hard work!![]()
Hey Gene, what type of drill did you use? I have a pack of blades & removed the safety strip, centre popped the hole position, but being carbon steel, drill bits wouldn't touch it.I was a little suspect when I ordered the DSPIAE cutter from Aliexpress but I have to say I am in love with this little cutter. I have the Amati cutter which is plastic and not capable of getting consistent, repeatable cuts due to it's design that allows the handle (blade) to move side to side. This unit is way better and is a solid, mini cutter. What I like:
1)This thing is solid. Everything is made of aluminum and very well put together....no plastic parts.
2)The guides are all metal as well, clearly marked, and accurate. 45 angles are a breeze with this cutter.
3)Razor Blades are the standard, single side blades that you can buy anywhere. All you have to do is drill 2 holes in blades to match the blade that comes with the unit. I setup my jig and drilled 50 blades in about 30 minutes....I like to change blades often.
4)Well designed. Cutter is designed so that the actual cutting is about an inch or two from the base of the handle. The result is that there is no pinching or "scissor effect" from trying to cut from the base of the handle...the blade comes down in a straight angle to the wood. The result is the cleanest, sharpest cuts I have ever gotten.
5)Price. I paid about 60 bucks all in with shipping, etc. It took about 2 weeks for mine to show up and I was very impressed with the packaging.
Honestly guys, this is a great little cutter. If you like or make due with the Amati cutter, you will love this cutter.
View attachment 448605View attachment 448602
Here is a comparison of the blade that comes with the unit (on right) and a standard single edge razor you can buy anywhere. (I removed the metal top or cover that comes on standard blade....it just pops off with a little prying) As you can see, you need to only drill the 2 holes and you will have infinite supply of cheap blades.
If you have any questions, let me know. No connection to company, etc.... I just love this cutter and wanted to share.
I used a fiber laser that I use for engraving coins. But a Cobalt titanium bit will do the job. Amazon LinkHey Gene, what type of drill did you use? I have a pack of blades & removed the safety strip, centre popped the hole position, but being carbon steel, drill bits wouldn't touch it.
Stuart
I also drill the hole a little bigger so that I could adjust the blade as needed. I put blade on, then loosen both screws...drop the blade down to where it is just touching the pad, then tighten screws.I used a fiber laser that I use for engraving coins. But a Cobalt titanium bit will do the job. Amazon Link
Thanks Gene, I do have some diamond tipped bits, which I forgot about, so will try them first. Another idea is to drill & tap M3 then use the slots in the blade for mounting with M3 knurled thumb screws, which I have.I used a fiber laser that I use for engraving coins. But a Cobalt titanium bit will do the job. Amazon Link
AHoy, Shipmates! My order for the DISPIAE cutter, of 3rd June, arrived yesterday the 10th. That's what you call excellent service, much easier than trying to get parts from España! Aliexpress keeps one well-informed of the order's progress all the way.I know it has been a lot of effort to get there....but you will be glad when you finally get the cutter....it is well worth it. I use mine everyday and still love it.
Please let us know your experience while using it.AHoy, Shipmates! My order for the DISPIAE cutter, of 3rd June, arrived yesterday the 10th. That's what you call excellent service, much easier than trying to get parts from España! Aliexpress keeps one well-informed of the order's progress all the way.
i received mine 5/29 greatly made tool problem installed blad3e is phoney order on amaqzon says it includes replacement blade hex wrench up datede cutting mat know where to be found found on amazon blde $10.00 no wrench . someone help if possible greatly appreciate it btw ot of stock at amazon. god bless stay safe all don
Hi Jim, here are comparative photos of my shop-made cutter & DSPIAE. I've used M3 thumb screws to replace the cap head ones. I didn't realise how small it is compared with mine.Please let us know your experience while using it.
