Baltimore Clipper Schooner Pride of Baltimore 1981 (1:20 scale radio-controlled sailing model)
Winter, as handling epoxy in an unheated garage matters, seemed to last almost till the end of April.
Finally the temperatures and my time have coincided enough that I may finally get this ostrich egg finished.
It seems the plastic egg deformed a little from the weight, so the two halves don't lay flat to each other. If I do this again, and for you folks thinking of using this method, I will put ribs inside the bulb to stiffen it, and fashion some sort of cradle to sit on that supports it so the bulb doesn't try to flatten out as the epoxy and lead set-up.
There were also pockets in the bulb that resin hadn't gotten to and I could hear the shot rattling around inside. If there's a next time, I'll place shot and pour resin in layers to ensure the resin gets everywhere it needs to be. What sounded like the biggest of these pockets was behind the flange? I modeled in for the plate to slide into. I opened the holes here to pour more resin in and hopefully fill this void.
I re-drilled to holes for the pin that will keep the bulb from sliding off the plate, and cut about a 3 inch length of 3/16" brass rod for the pin.
I mixed very fine sawdust from my band-saw with the epoxy to make a paste of it, and buttered both sides of the bulb, placed the pin, and plate, and put the other half on.
I used a sliver of wood as a wedge to hold the seam on top, where the plate enters, as close as I could, making something of a gap at the bottom. The epoxy butter filled this in fairly well, but the seam's open almost all the way around, which I'll fill with more epoxy butter.
The bulb also needs some clean-up from epoxy runs and cardboard that stuck to it; and I intend to wrap it in glass cloth as that'll be stronger than the resin alone if the boat should hit a rock or something.
Well I really hoped to have this one sailing, if not finished this summer, but then I went and had a stroke, which threw a wrench into a lot of the plans of mice and men.
Not that I'm a prolific poster, or anything, but things are on hold as I relearn some fine control on my left side and quit walking in circles.
OMG, Jerry, that sucks beyond comprehension! I wish you well and, hopefully with proper physical and occupational therapy you will regain your fine motor chops. Please get well and be well, my friend!
Pete
In Baltimore there is a memorial to those lost in May 1986 when Pride of Baltimore suffered a knock-down and sank with the loss of her captain and 3 crew members. Next May will mark 40 years since the sinking.
The memorial is now undergoing refurbishment. Here the Pride of Baltimore II's crew is down-rigging it to do just that.
The above image was posted by Pride of Baltimore II on Facebook along with this image by Greg Pease (which I lightened slightly)
When I mixed up epoxy to glue the pin-rails on Constellation, I mixed extra to do Pride's ballast bulb. The epoxy had sawdust mixed in and yet, was still thin enough to run out of the gap between the halves; so I spent a lot of time putting it back up there.. There's actually a portion of pantyhose over the bulb acting as glass cloth would. I hope the cloth will strengthen the bulb against impacts somewhat.
Obviously, there's some sanding to do, and more epoxy to apply, when it is finally done, it'll get painted Moss Green like the bottom of the hull.
It was a nice day out today, so after mowing the lawn, I took the bulb outside to go over it with a disk sander, which went much quicker that I thought it would.
Thus encouraged I mixed some epoxy and gave the thing a coat, this time without the sawdust mixed in. I also glued on the other bow pin-rail on Constellation.
The bulb will get another sanding and a thin coat of epoxy, but I don't think it'll need any more than that. I checked on it before posting this and it's still tacky.
The lady comes home tomorrow from a visit to her grand kids, so it'll get another day to set-up fully.
The bulb did indeed get another sanding and coat of epoxy, as did the fin. Then it got sanded and primed, twice, then sanded and painted Moss Green, twice; then sanded and clear-coated, twice.
It's pretty much done, though I haven't had it in the model yet, and it may need some sanding to fit in it's centerboard trunk.
