1:64 cutter SHERBORNE, 1763 [COMPLETED BUILD]
Poland
Hi Everybody.
So here I start to present the build of this 1763 cutter.
Before that, just a quick point on the fact that all my previous modeling, as seen in my youtube playlist https://www.youtube.com/playlist?list=PLE86FA4A2FAC0D615 alwyay has been a mix of wood and cardboard.
The 2 high seas fishing boats seen below, just like the other models, have all wood structures but the planking is always 2mm thick cardboard. In fact I have always been a fan of cardboard planking, as long as it would be painted in the end :).
So the cutter SHERBORNE is in fact the first truly all wooden project. Plus the fact that it is clinker. This obviously required a bit of adaptation. But "a bit" of clinker was in fact part of my first ever model, the cod fishing dory seen in youtube.
I apologise for the not so good photos quality, but I had no better conditions at the time:
One of my main joys in modeling is finding materials out of the mainstream. So instead of buying the usual woods I prefer to find objects of daily life that may be used. Fruit baskets, kitchen ware, coconut broom threads :), etc.
So for SHERBORNE I am using for the keel wood from "salad tongs" and for planking "coffee stirrers".
The base for the model is the original old english plan, plus a lot of observations from other SHERBORNE model builds. I usually prefer to give my builds as much detail as possible, with a bit of "wear".
The photos already show my work at some advanced stage, but I believe it is still possible to see every construction detail before being covered up by deck or paint. The beauty of building in wood is that it should stay unpainted as much as possible :).
Will gladly answer any questions from all of you.
Hi all.
The SHERBORNE is said to have 3 pounders. Does anyone know how these small cannon balls were kept on deck? Was it inside crate boxes for instance, or they were on racks? For this small caliber internet search is not very fruitful. Thanks!!
Hi Everybody.
View attachment 215356View attachment 215357View attachment 215358View attachment 215359
View attachment 215350View attachment 215351View attachment 215352View attachment 215353View attachment 215354View attachment 215355
View attachment 215360View attachment 215361View attachment 215362View attachment 215363View attachment 215364View attachment 215366
Hallo @cachinare
How is your work on the SHERBORNE going? Would be great to see some updates of your progress
Hi Everybody.
you mentioned in another topic, that the Sherborne is finished - maybe you show us in the final status (or also in between) ?
Congratulations for finishing this project - clinkered hulls are very complicated - well done
Thanks. This one was specially difficult because of the size of the cutter, about 20cm and thickness of the planks. Eventually bigger ships are easier, but it is not in my plans to repeat a clinker one.
When building this cutter Sherbourne, I was somehow puzzled by the 4 yards it has. I could never find the explanation for that in the rigging so I always thought it could be eventually a "mistake".
But recently I found this model of a revenue cutter in the Greenwich museum collection showing the same 4 yards.
Still, I don´t still understand the purpose of the lower yard, because it´s not holding any canvas.
Does anyone have an explanation for its use in the mast?
The lower yard is for spreading the sail ... btw nice "clone" of my Sherbourne you did :-D
Dirk
Hi Dirk.
Thanks for the reply. Indeed it makes all sense, that yard spreading the sail. I just wasn´t "seeing" it :rolleyes:.
And yes, this is an almost copy of your build. Years ago when I found those so many photos and details you were providing, I couldn´t resist to build this cutter. So thanks for all your photos and postings.
I checked your webpage with other great builds also. Great work.
