Thanks for this compliment.A very good result - Bravo
"space" is never a problem here in SOS, so if you have a documentation of your builds, we are very interested to see them in building logs in this areaThanks for this compliment.
I suppose you have a lot of experience on the forum. Do you think it is interesting for the memberswhen I put the 12 remaining completed builds on the forum or do I use too much space? I kept a written log of every one I built and in the mean time I scannen all the photographs from before the digital period, so it is quite easy to put a selection of these photos on Completed Builds.
Wow, it's looks beautiful modelIn 1993 I have built the 'Elidir'. On completion I give her the Dutch flag and her name was changed into 'Runamara' , after the title of a Dutch book about a mermaid.
Thank you!Very handsome model!
This is Fish With Ed. This is my first wood build. Having trouble with instructions. Need some answers on the Elidir. How much glue do I put on the frame when putting on the hull planks since the frame has to be pulled back out? I also have 2 pieces of the keel and I believe I need one. Am I correct?Thank you for posting so many pictures of your Elidir build. I have been trying to build the Constructo Elidir for quite some time, but often get discouraged and give up for awhile. I might be working on something above my skill level, but I also think it has a lot to do with poorly translated instructions. I may ask you a question or two as time goes by. I am currently planking down by the keel, which it a bit tricky.
Well, I'm having a bit of trouble with posting, but I wanted to tell you to avoid gluing to the framing at all. Instead, use brads to temporarily tack the planks to the frames. Use glue ONLY in between planks. Will attach a photo if I can.
