No, it becomes colourless, rather transparent.Thanks, Piano! You're doing a fine job. I did hardly see any better achivement on sailmaking so far. Does that glue turn into any yellowish shade?
Thanks, that's good to know!No, it becomes colourless, rather transparent.
A very nice main sail with all those reef lines, Adi. The model is getting more and more impressive.Thanks for all likes. Done, the main sail is hoisted and moored. Once again, everything takes time.
Sehr cool!Very good result - Bravo
wie cool ist das denn
As a beginner this is something I often encounter.After taking a closer look at all the individual parts and their interaction, I came to the conclusion that this should be possilble.
Set the keel into the base plate, part A9 behind it.....nasty surprise, the tolerance devil has struck.
Doesn't look good, so fill it up.
before...after...
