I have a little table saw that I made that I mostly use for cutting planks. It has a 4" 80 tooth blade and turns at 3450 rpm. Up until recently it has worked quite well but now It seems to want to cut tapered planks. If I am cutting ,040" planks it will start out cutting .040" but at the end of an 8" plank it will taper out to almost nothing. I am holding the work against the fence as tight as I can but it wants to move away from the fence I think. I clamp the front of the fence with vice grips so at least the front of the fence isn't moving. I've tried adjusting the fence but I'm not sure which way to go or if that is even the right thing to do. Any Ideas?
