Here's the real story though ...
**VIEW THREAD HERE** |
A very good video - thanks for sharing with us - very interesting (and I can understand your decision to build this ship modelHere's the real story though ...
So do I!A very good video - thanks for sharing with us - very interesting (and I can understand your decision to build this ship model
I dabble in Taxidermy a bit well at least my own anyhow. for water effects I use a product caller Polytranspar Artificial water or for small jobs I use Envirotech lite Pour-on they dry crystal clear is self leveling and can be colored very easily to simulate any type/color of water. I use it to create waves. and even used it to create a splash effect of a bass jumping out of the water with water streaming off the fish's fins, back and dripping off the fishing line. there used to be some plastic beads that could be heated till liquid spread out on sheet of foil to a desired shape then once hard you could peel it off set it in place and use a hair dryer to soften it to create the curl of water as the bass jumps out of the water you could also create ripples and drops once this was to your liking you pour enviroteck over it and the fish to make everything look wet and seal everything in its place. you can pour polytranspar and envirotech onto sheet goods like foil keep working it to a shape you want till it starts to set up then shape it how you want with a heat gun.
Mystic Seaport in CT, has plans available for the reconstruction / retrofit of the Morgan. They make those plans available for purchase from their archives. They are not cheap but, but fast than drawing or rescaling something else.
Model Shipways has a Kit of the Morgan ... their plans are copies of those of Mystic's ... Although it seems that there is also some sort of practicum included with the kit. that kit is in 3/16th" or 1:64 scale depending on how one looks at the wold of models.
Is it the Antarctic service medal ?I didn't want to high-jack another thread with this ... but it was commented about having an avatar ... any guesses as to what mine is specifically ... Here is a hint to get what might no be a clue to Captain obvious, it's a military medal ... the ribbon portion.
I wintered over as a part of a tour of duty while in the Navy. Served TAD with NOAA.
