When the prep work is done properly, the foundation for a neat surface is laid. But with that thin balsa you can't afford to do much sanding. But this already looks very neat, so that will be fine! Full confidence in your skills, Dean.I am finished with the top of the wings, sanded and putty in a few places. The paint will also help me see if I have any surface imperfections.
I have one more wing half to skin on the bottom.
Then I can paint and do final sanding.
Then I can move to the fuselage.
That’s awesome you got to work on a P-38!Well I think having the wings done is a big step, but easiest step of all, except maybe the horizontal stab.
Booms and fuselage have lots of bends to work things around.
Your looking good so far.
Oh did I ever tell you I actually got to work on a real live P-38 while back in the Air Force. Our base was supporting the Commerative Air Force project on rebuilding a P-38.
Thanks Peter, there were a few areas that are thin and some that needed putty to avoid sanding through. But the paint will give it strength and fill in any wood grain prior to application of the aluminum plates.When the prep work is done properly, the foundation for a neat surface is laid. But with that thin balsa you can't afford to do much sanding. But this already looks very neat, so that will be fine! Full confidence in your skills, Dean.
Thanks Daniel, I have been contemplating the room needed for my work area. I may have to rearrange to make enough room, or move my work to a larger table. Will see…Looking good Dean! Are you going to have enough room on your work matte to accommodate the fuselage?
Thanks Chuck! She’s a big bird at 1/16 scale. It’s the same scale as my Camel, however it was a much larger airplane. So the wingspan is 40” at 1/16 scale.Dean! Superb!
I love the magnitude of the bird! Following your log is taking me way back in a good nostalgic way to 48 scale P-40s attached to my bedroom ceiling with fishing line. You know the rest.
I look forward to your progress reports and thank you for sharing yourself.
Blessings. Peace. Gratitude.
Chuck
That looks like a tight fit, Dean. And a template is with all those curves the best option.I did 4 panels or pieces on the center fuselage. I had to make paper templates…this is going to take a while!
This is good stuff Dean; I love your precise work.I did 4 panels or pieces on the center fuselage. I had to make paper templates…this is going to take a while!
As I begin the fuselage, I realize just how much work this is going to be to cover it all with balsa wood and then aluminum panels.
Oh well…no rush, steady as she goes!![]()
