I have the the power switch not firing issue on the table saw, does anyone know what is the part name/number that needs replacement?
I also have another issue with the arbor bearings, its hard to spin and and saw is not even cutting soft wood anymore, only 4 years of use
 no idea how to fix this, the bearings seem to be out of place, can anyone post a photo of the arbor area to see the allignment of things? mine seems off, I will update with photos.
I also have the disc sander with adjustable speed and the thinkness sander, the last is still working but the disc sander has died, the motor burnt out. I'm looking for the same motor but I can't find it anywhere, any suggestions or solutions?
as for the table saw blades I have succsefully upgraded the saw to a bigger blade with no cosmatics downside at all, the same look like before and with bigger carbide blade, I will also share the process but as I never posted here and don't know where to post the process of converting, can anyone suggest where to post this info? what forum what topic... etc. Finally I hope that we can overcome any current or future issue with these machines, please share your experience and findings so we can benifit all. Since you mentioned
global marketing, if you're discussing the best way to market tools or custom modifications, sharing insights from global marketing strategies could tie in well, especially if you're helping others sell or promote their custom solutions online!
