- Oct 9, 2020
thank you for the feedback. Indeed I purchased some of that pretreatment conditioner. I found out yesterday evening about the basswood not easy to stain. I thought it was glue that was doing that but it isn't. Something about basswood makes staining it look like crap. I should have done my homework better, but I didn't think it was going to be a problem. oh well, lesson learned.I just noted that you are using basswood for the decking. I don't think it's easy to stain basswood. I have seen people get pretty irregular penetration leaving a mottled appearance. I would be sure to create several test panels before committing to the finished deck. You might even benefit from the use of something called a pre-stain wood conditioner (sort of like a sanding sealer) - it evens out the penetration of stain and makes it more uniform in appearance.
You got this!
Great. But don't give it a go just after reading instructions! I create a test panel every time I do something significant (staining, varnishing, nailing, trenailing, etc. etc. etc.). It's a rare day when my first test is used on the ship. You claim to be impatient - but little is gained when you have to tear out something you thought was completed. THAT is what tries my patience...![]()
Stain Basswood in 7 EASY Steps + Best Stain Colors [2026]
You can stain basswood. Basswood's light color and porous nature make it ideal for staining, resulting in a vibrant and even finish. Always use particle stain on basswood for the best results and seal with a topcoat to enhance its longevity and appearance.woodworkly.com
good point. I am all for testingGreat. But don't give it a go just after reading instructions! I create a test panel every time I do something significant (staining, varnishing, nailing, trenailing, etc. etc. etc.). It's a rare day when my first test is used on the ship. You claim to be impatient - but little is gained when you have to tear out something you thought was completed. THAT is what tries my patience.... I think you will rather enjoy the testing process - it gives you a chance to experiment and achieve what you are imagining it will look like.
I suspect my secret unconscious agenda is to build all the models, read all the books and drink all the beer before I die!
I do indeed. It is POF HMS Enterprize, but thanks to Doc Kattner, I have seen the light. I will stick with the Constitution until it is finished, even though I would love to see it fly out of my livingroom window at Mach 2Impatience. It’s a funny thing really. Everyone knows that it’s never, ever helpful to be in a hurry.
Sure, it’s good to be ‘on time’ but only if we achieve that through thoughtful planning and allow ourselves time to get there.
Hurrying, rushing, without thought is always bad. Yet we all have to fight against that panic inducing voice in our heads screaming, “Hurry up! Don’t be late! Don’t miss the deadline! Don’t get in trouble!”
That voice in my particular case is mostly my father’s - a driven man, but it seems to me that the entire 21st century is in a mad rush. It is hard to walk when everybody around you is sprinting.
This is certainly a good hobby for learning and practicing patience. It’s helping me slow down and simplify my retirement, but I have started my next project before finishing the current one so I clearly have some way to go yet.I suspect my secret unconscious agenda is to build all the models, read all the books and drink all the beer before I die!
Do you have your next model in mind already, Jack?
POF HMS Enterprize
I'll say this as gently and lovingly as I can...a builder would be wise to sort out the routine things of ship modeling before he/she engages with the exotic. My current POF project is exponentially harder than my previous POB project. That said, you have more experience building ships than I do so maybe that transition will be smoother for you...I do indeed. It is POF HMS Enterprize, but thanks to Doc Kattner, I have seen the light. I will stick with the Constitution until it is finished, even though I would love to see it fly out of my livingroom window at Mach 2
i don't really allow that to limit what I will try to do. I like that feeling of "that is hard to do". I have already done a few POB models and I am bored of those. I picked the constitution because there is a lot of building and painting, for which I don't have a lot of experience. For the POF, I have purchased a couple of books on the subject and I will use those to guide me. The logs on this site will be helpful too.I'll say this as gently and lovingly as I can...a builder would be wise to sort out the routine things of ship modeling before he/she engages with the exotic. My current POF project is exponentially harder than my previous POB project. That said, you have more experience building ships than I do so maybe that transition will be smoother for you...
turns out it's the porosity of the basswood which makes it difficult to stain. Apparently it soaks up stain like crazy, which makes it difficult to get a uniform coverage. I'll try out that pretreatment conditioner to see if that helps. If the test pieces look like crap, then I'll just seal then varnish the deck.thank you for the feedback. Indeed I purchased some of that pretreatment conditioner. I found out yesterday evening about the basswood not easy to stain. I thought it was glue that was doing that but it isn't. Something about basswood makes staining it look like crap. I should have done my homework better, but I didn't think it was going to be a problem. oh well, lesson learned.
At some point I will make a decision about if I want to stain it or just varnish it. That I am used to doing.
Yuck. There's you problem. Great wood for structural work, NOT for finished surfaces. It doesn't stain well. Models made of basswood are painted... because it's basswood.it's just basswood
I am wondering if I could find a hardwood that is in strips. Any suggestions?Yuck. There's you problem. Great wood for structural work, NOT for finished surfaces. It doesn't stain well. Models made of basswood are painted... because it's basswood.
How about Holly? It has fine grain and stains well.I am wondering if I could find a hardwood that is in strips. Any suggestions?
You have a million options, as I stated only a few in my last post (Model Expo, Modelers Center, eBay). FELLOW MEMBERS: Please tell this fine gentleman where he can purchase some 3 or 4 mm wide deck planking strips from a decent hardwood.I am wondering if I could find a hardwood that is in strips. Any suggestions?
