- Oct 9, 2020
Now things get a little tricky. Planking the aft side. Since the stern is narrower than mid ships, the planks will need to be tapered at the stern.
Thus far I have used 21 planks for the mainhatchway. From the edge of the hatchway to the waterway, there is 2.7 cm. Each plank is 0.3 cm so there are an additional 2*9= 18 planks.
Next you have to measure the width at the stern from waterway to waterway. In my case the measurement is 8.6 cm. Since I want the same number of planks at the stern as midships, then I have to divide the 8.6 by 39 which gives me 0.2 cm plank width. Thus I will have to taper from 0.3 cm to 0.2 cm.
