Unfortunately this means that this fence https://micromark.com/products/accuriser-ii?keyword=saw fence is not necessarily fits directly on genuine Proxxon FET unless proven otherwise. Actually I believe it will not fit on Proxxon saw. The Proxxon does not have a feature to secure the farther end of a fence to the saw body.I did have a Proxxon exactly like the Micro Mark one which has the variable speed control
By the way. Guys. This micro-mark model looks exactly as Proxxon FET but had a ripping fence with no seeming problems as Proxxon saw has. Fence looks simple and reliable. Does anyone owns this model? Could they share their opinions about this model. If I did not own a Proxxon FET I would probably took a risk buying this saw. Today it is also much less expensive to Proxxon.
Do not forget the Proxxon FET and this model of micro-mark saw they have tilting saw feature which Byrnes do not have.
Yeah, yeah, I know Byrnes has some expensive attachment to do tilted cuts.
MicroLux Mini Tilt Arbor Table Saw | Precision Cutting Tool | Portable
Get precise cuts with the MicroLux Mini Tilt Arbor Table Saw. Its high-torque DC motor and speed control make it ideal for wood, metal, and plastic projects.micromark.com
I got this, it is the FSK from Proxxon. I bought it second hand a long time ago, without fence. I ordered a new fence and got the upgraded version like the micro-mark. It works good. When setting up the fence you need to check if it is parallel to the sawblade. I did this by making markings on the table where I always can measure on 2 points. After that it is easy to setup.Does anyone owns this model? Could they share their opinions about this model.
It is the onder model of Proxxon the FSK, not the FET. 2 different machines. The FET got already micro adjustments.You are getting mixed up, the Micro Mart saw doesnt look like the Proxxon FET, The Micro Mark saw has a different fence and also it has a variable speed control, the previous Proxxon model looked exactly like the Micro Mark one, thats why I said if you are going to get the Micro Mark saw get that fence to go with it,
best regards John.
Don't forget Preac. Made a table saw and a thickness sander. Quite plentiful a few years ago. After Jim died, have gotten rare I bought quite a few of each I also have Jim byrnes model machines.You guy's are aware Byrnes is back in business, right? The website hasn't been updated to be part of it yet, but you can call them and order tools, from what I understand.
