|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
				 hozodesign.com
					hozodesign.com
				Fair putNow why would go disparaging something with no practical experience using it? That's not helpful. The Neoruler is expensive, but I got lucky and found one unused on ebay for stupid cheap... Cheap enough that I didn't mind spending a little more to buy the caliper addon from the manufacturer. It's not a gimmick, it's professional quality and it's spot on. Accurate down to. 001, metric, imperial, fraction. It's not cheap but it is cool. Do you need one? No, but I'd venture there is a lot of stuff in my shop I don't need but I'm glad I bought and that I use. Your mileage may vary.
 t
tHi Bill, that's right. In total there are 24 different sizes/shapes of those Pfeil palm gouges. I have 12 of them now, mostly the smaller sizes.Very nice magnifier and light. I also see that very nice Pfeil carving set.
Bill
Purchased them all and now safely in my "Use at some Stage" shelf. Thank you again Steef66. Now I have to decide what to use them for. I have ideas but they need to come to fruition after I finish making a shamble of the San Juan Nepomuceno hull.There is a little tool for it on the market. And you have to u screw it with the bur or the pin in the handpiece.
STRONG 210 105L 102L 102LN& Marathon 37L1 H200 Handpiece Drill Pen Wrench Electric Nails Drill Manicure machine Accessorie Tools - AliExpress 66
Smarter Shopping, Better Living! Aliexpress.comnl.aliexpress.com
There is a discription in the link how to do it. The first time loosen it could be a little tricky because they are tighten real hard. To hard. After replacing it goes better.
But have a look here where you can see a picture of the tool I use
Tutorial - An easy introduction to making wood ornaments by Stephan Kertész (Steef66)
For the Modelbouwer I wrote an article about carving and I wish to share it with you here. I hope this will an educational subject to get more people into carving or take away the fear on starting with it. Sometimes you come across models of historic sailing ships that have beautiful ornaments...shipsofscale.com
For wood, these are burn very fast the wood. There are other ones for wood. But for metal, to round the top of nails, perfect.I combined its purchase with a set of cup burrs.
Your welcome, maybe start practise on a piece of wood.Purchased them all and now safely in my "Use at some Stage" shelf. Thank you again Steef66. Now I have to decide what to use them for. I have ideas but they need to come to fruition after I finish making a shamble of the San Juan Nepomuceno hull.
That's a nice handpiece you bought. Maybe something for @Maarten no more excuse to rotary carving on holiday.
   Next time I'll use DeepL @Maarten
I will use this set for the copper nails. I also ordered the set more suitable for wood together with some small drills and wood cutters.For wood, these are burn very fast the wood. There are other ones for wood. But for metal, to round the top of nails, perfect.
How and what would you use those bits for?I will use this set for the copper nails. I also ordered the set more suitable for wood together with some small drills and wood cutters.
I have the same tool and like the brushless motor, quietness while operating, and portability but... I hate that they didn't implement a better knob for the speed control, also a pedal would be a much better idea to stop/start between changing the bits. If frequently changing the bit is required, then it becomes a hassle, IMHO.For making the figurehead and many other ornaments I bought a nail drill following the advice of Stephan @Steef66 . I had used the proxxon flexible shaft before for this kind of work, but such a nail drill gives much more freedom of movement and for the heavier work I can always fall back on the Proxxon.
It is quite small in size and has a clip so you can take it with you, clipped to your belt.
View attachment 505380t
