- Dec 25, 2021
Fantastic build and skill on such a small scale
As a builder of a (other type) 1:96 model: My great respect for the builder of this 1:96 model. And for the manufacturer!
Hi Allan. That was also my thought when building my POF Bluenose from the YuanQing kit. But then I realized that I would also have to adjust many other parts from the kit that fit the frames. Including deck beams. Then many recesses would have to be made smaller to fit neatly. With the result that I would have to make a lot of parts new myself. It goes from 'bad to worse'. It would have been a scratch build of half of the structure. Then I decided to focus my attention on other details. That are the pros and cons of building a kit and still have a lot of fun building a 'not overall correct' kit... do the instructions give the builder the correct dimensions so they can decide if they want to sand them to the correct size ..
Compared to others under construction it looks like a bit too much precise. A matter light, maybe?
My experience with the hoy would rather suggest the manufacturer to laser cut parts, expecially the long ones (e.i. beams) a bit longer or larger than officially required. Any redundancy could be easily trimmed. Any gap, on the other and, is always an annoying sat back.Hi Allan. That was also my thought when building my POF Bluenose from the YuanQing kit. But then I realized that I would also have to adjust many other parts from the kit that fit the frames. Including deck beams. Then many recesses would have to be made smaller to fit neatly. With the result that I would have to make a lot of parts new myself. It goes from 'bad to worse'. It would have been a scratch build of half of the structure. Then I decided to focus my attention on other details. That are the pros and cons of building a kit and still have a lot of fun building a 'not overall correct' kit.
