- Sep 28, 2024
Excellent progress2 1/2 days worth. I bought a set of jewelers tweezers that have helped move this along quicker. I will varnish each side as I complete to protect from oxidation and help seal the plates.
Good afternoon. Looking very good. Nice progress on those copper plates. Cheers Grant2 1/2 days worth. I bought a set of jewelers tweezers that have helped move this along quicker. I will varnish each side as I complete to protect from oxidation and help seal the plates.
Hi2 1/2 days worth. I bought a set of jewelers tweezers that have helped move this along quicker. I will varnish each side as I complete to protect from oxidation and help seal the plates.
I used the copper that came with the kit. I started out using medium CA but changed to thick CA which didn't run as much as the medium.Hi
2 additional questions on the copper plating:
- Are you using the copper provided by Caldercraft in the kit or are you using a ribbon copper?
- What glue do you use to place the plates? Medium CA?
Thanks
ThanksI used the copper that came with the kit. I started out using medium CA but changed to thick CA which didn't run as much as the medium.
Chris?? Sorry, I am at a loss on who you are referring to.
Hope you are feeling better!!
That is awesome. Congratulations.On a side note my youngest daughter just got accepted to Oxford University in England for her PhD.
PERFECTLY STATED.But you will definitely need to consult some books to properly complete this adventure.
I have done it and I hate it even though the rope looked good. I used the cheap set up from Syren but as I usually only rig schooners not a lot of rope or sizes are needed. If I ever have to rig a frigate or ship-of-the-line I would make my own rope as there are dozens of circumferences needed so it would save a lot of money and I would use the set up from Syren, or at least give it a good try before looking to buy something more complex and expensive. I am sure there a lot of members with far more experience in making rope that will be able to help you make a decision.Do you have any suggestions on rope making equipment?
Very nice progressFinished the upper deck cannons rigging and now working on the quarterdeck assemblies (fun part compared to cannons riggings). Starting to look somewhat like a ship. The screen assembly is located for a fitting and will be completed and set aside this weekend. On a side note my youngest daughter just got accepted to Oxford University in England for her PhD. Now I'll have an excuse to go see her and visit the real HMS Victory while there.
