Many thanks Grant.Good morning Neil. Congratulations. This is really neat and accurate work. The way this kit has designed the frames is spot on - unlike my my version. You are owning this build. Cheers Grant
Thank you AlbertmaryNicely put together, congrats!
Thank you. Phew!They look like the mast steps. If they are not in the kit, maybe make your own.
Inboard profile prior to being converted to receiving ship when she was demasted.
From the contract of 16 July 1776 for her sister Aurora (28)
MIZEN STEP ….. The Mizen Step to be sided 14 ½ ins, of sufficient Depth on the Keelson, The Arms 5ft 6ins long each, & bolted with 6 bolts of 1 ⅛ diar.
MAIN STEP ….. The main Step to be sided 1 ft 11 ins and 15 ins deep on the Keelson and of a length to slide easy by the Stantions of the Well.
FORE STEP ….. The Fore Step to be sided 1 ft 9 ins, in Length 10 ft 6 ins, bolted 6 bolts of 1 ⅛ diar
Thank you kindly Alex. I just hope any obsession I and others may have in doing research and sharing the details does not offend anyone even in the slightest. I fully realize it is a hobby for the vast majority and some builders are interested in accuracy, some not so much. And that is as it should be with a hobby, we all get to choose. Those members here with years of research experience are only trying to offer choices, never decrees, for those that are interested.Allan, I designate you Chief Detail Engineer and Researcher, and I hope you will keep us correct when we start our build. Be ruthless...Maybe I should call you Chief Herding Dog ! You are awesome.
Hi Alex. Thank you for the compliment.Neil,
You are building an impressive structure at lightning speed ! Your joinery is beautiful; it looks like all the beams and lodging knees fit well lengthwise.
I noticed that a couple of the lodging knees on the larboard side (about beam # 6 from the bow) are not even with their corresponding beam...Were all the sheets where the parts were located milled to the same thickness? Are you planning on planking this deck?
I don't see any notches on the beams for the carlings; cutting them in will slow you down a bit.....
Congrats. impressive work.
Alex R
Enterprize's original plan (https://collections.rmg.co.uk/media/547/635/j6316.jpg) shows no figure head. The Medea, of the very same class, here below, hints a human figure head. So... who knows?Good morning Neil. Very impressive work. I have a strange question. Is this the same enterprise as the CaF model I am building as I have a Lion figurehead and your is a person?https://collections.rmg.co.uk/media/547/635/j6316.jpg
Hi Grant. Two different model companies I think. Not too sure which one is an accurate take on the ship.
Hello Gentlemen. Let’s go with “who knows” until someone in the know tells us otherwiseEnterprize's original plan (https://collections.rmg.co.uk/media/547/635/j6316.jpg) shows no figurehead. The Medea, of the very same class, here below, hints a human figurehead. So... who knows? View attachment 506603
