Thank you Daniel!Painting those parts brings that engine to life. Really well-done Dean.
A impressive engine, Dean. Liked the spaghetti exhausts pipes at most.The broken belt…the provided rubber belt for the fuel injection unit was broken when I tried to assemble it. The rubber they molded it with doesn’t stretch well.
So there was no belt…until I searched the entire house looking for a small rubber band that would be right length and width. Lucky for me my granddaughter had a bag of small rubber bands in different colors…bingo!
Here is the one I found that worked, of course I had to paint it because it was green!
That done I looked ahead at the instructions…always a good idea…
After the plug wires you add the exhaust pipes and bracket, and the throttle linkage and springs. The problem when adding the exhaust pipes is you have to have a firm grip on the motor and the more tiny parts I keep adding the harder it gets to find a place to hold it. At the moment that is down to the cylinder heads where all the plug wires will be! So…I decided to add the exhaust first for that reason.
View attachment 505579View attachment 505580View attachment 505581View attachment 505582View attachment 505583
I did some dry brushing to represent heat cycling of the exhaust. I didn’t like that they cast some numbers to help with assy on top of the exhaust and one shows up by the collector. In hind see got I wish I would have filed that off. Oh well…you may or may not see that once the car is finished.
In addition I am going to add the throttle linkage before the plug wires too to ensure the wires are routed out of the way of the linkage and springs. Seems like the better approach to me.
As she sits now…View attachment 505585
Oh and I measured it from the exhaust to the front of the motor…we are at a little over 8”…
Thank you Peter. This inline 12 cylinder was a monster of an engine…and the car ruled the race track when it came out.A impressive engine, Dean. Liked the spaghetti exhausts pipes at most.
The most impressive thing, to me, is an high performance flat-twelve exclusively air cooled. The Fiberglass manifolds for the gearbox and differential air cooling are amazing as well. Great achivement with the paint job simulating the side effects of prevopiously red hotted exhausts. Respect!A impressive engine, Dean. Liked the spaghetti exhausts at most.
Thank you!The most impressive thing, to me, is an high performance flat-twelve exclusively air cooled. The Fiberglass manifolds for the gearbox and differential air cooling are amazing as well. Great achivement with the paint job simulating the side effects of prevopiously red hotted exhausts. Respect!
Way back when I did model cars, I used to use the insulation from solid core hook-up wire I got from Radio Shack in 22,24,26 gauge. I would pull the wire out of the insulation (the solid core rather than stranded made that easier) because the insulation took on more natural curves than I could ever get by leaving the wire in. Of course, yours is 3 times the size of the 1:24 models I built, and Radio Shack is ancient history, but you can still buy hook-up wire at auto parts stores or home centers.Not sure what to do yet, I am looking into options…
Unfortunately at 1/8 scale that would be almost impossible. However I can do a few things that help it appear to be tighter. I will experiment.Well Dean not bad but, to me while the diameter may be at scale the weave in the wire appears too big as in its not tight enough.
