HMS Enterprise 1774 POF 1:48.
Even with a “BOMB” of a jig I still messed up two timber bevels.
I don't think you messed up. From the looks of the timbers in the jig, you had the choice of making the tops of the timbers flush or the bottoms, but not both. I would have picked the tops as well. It doesn't look like there was enough meat at the bottom of those two (and some others) to begin with.
Good evening Russ. I agree, it’s not a mess up….more like I got everything seemingly perfect until they had to be put together. There probably was enough meat and I just took too much off, even tho I thought I was being conservative. I’m actually very happy with the outcome so far but it is early days. Cheers Grant
Good afternoon everyone.
What I learned from reading every build log (completed or otherwise) is that everyone built the hawes timbers out of the jig. No instructions and this seemed logical so I went for it.
The first cant frame and hawse timbers. Prelim sanding done but I will wait for all the frames to be done to finalise the sanding.
Even with a “BOMB” of a jig I still messed up two timber bevels. I have cut and inserted a rectangle filler wood piece - I will trim and sand these when glue is dry - will be awesome when done;) RED ARROWS.
View attachment 508672View attachment 508673
To ensure correct fitting I use the C section of the jig :
I had loads of fun and pretty happy so far….holding thumbs.
Cheers Grant
I really like how it's turning out!! I'm already looking forward to when I start assembling my frames by keel)))
Cheers Grant
Perhaps not ‘conforming the rules’ but the outcome with all those curves fits very nice in the jig, Grant. Have confidence in your own skill and you really gonna love this type of build.
Good morning Peter. Thanks for your vote of confidence. This jig once built has very little room to play with (probably a good thing) but I couldn’t see how I could make these Hawes timbers and first cant frame in that small space- my outcome appears good however we all know what “appears” did ROTF . Cheers Grant
Hi Grant,
I think you have the correct approach. I had a hard time putting those timbers in with the building rig in place. I wish I had done it the way you are planning.
AR
Hi Grant,
AR
Good evening Alex. I am sort of guessing a lot here. As fantastic as this kit is designed I am finding certain aspects difficult to bring together. The transom structure is also something which has me in a state of uncertainty as to how best to proceed. It is super fun however that concern of this could go totally “pear shaped” lingers long into the night ROTF. We will find out one way or another if I’m doing it right or not. The instructions as you know don’t really assist too much. Non the less my enjoyment factor is really high. Cheers Grant
Good morning
A very boring post: I am plodding along putting the frames together : 50% done of the “square frames”.
When I get bored of frames I cut out some notches on the beams. I don’t have any fancy milling machines etc so it is up to a chisel blade…..1mm deep (supposedly ROTF )
One thing I know is that I am going to be doing so much wood sanding and finishing on this model.
Cheers Grant
Good morning
Cheers Grant
Hi Grant. Are those beams of solid wood? I can't guess from your pics. Thanks in advance! Cheers.
Good morning
Cheers Grant
Very cool. Today I will start working on solid frames. It is always interesting to watch such work.
……… When I get bored of frames I cut out some notches on the beams. I don’t have any fancy milling machines etc so it is up to a chisel blade…..1mm deep (supposedly ROTF )
Cheers Grant
No mill but impressive hand-i-matic notches with that chisel :).
Thanks Grant. So some kit bashing if we want to have the figurehead as in the Marshall print.... Oh well.....
Keep dropping hints, Allan. You'll turn him into a woodcarver by the time it's finished.
They look very good to me, very consistent.
You know, it's the plodding parts of this hobby of ours that I find so difficult. Framing, planking, gun rigging and so forth become production engineering - factory work. Assembling the thousand pieces of a plastic tank's tracks is an example from another genre, or rigging the ignition wires on a B-17. How do you plod on while maintaining your usual high standards? I tend to get sloppy, distracted or simply avoid the workbench until all interest in the project drains away.
This is one of those questions that seem to be about modelling but actually concern our full scale lives. I'm struck by your photos of beautifully completed boats in the setting of a beautiful house while my rather scruffy vessels (mostly uncompleted) are perfectly framed by my scruffy little flat. Our models become self-portraits to those who know how to look at them. ROTF (and also a little bit of :rolleyes:)
