I bet you do!At this scale I don’t have the skill with the blade to achieve that tapered notch.
yet to cut myself with a file if it slips
It is my honor to think this way. This is a beautiful boat. I hope your finished product will definitely be better than mine.Good morning. Thank you very much. It was your model which inspired me to buy this kit. I hope that I can get mine close to your beautiful Enterprise. Cheers Grant
Good afternoon Gentlemen,
My work the past 2 days has filled my swear barrel with little result:
Cheers Grant
Better start looking for another barrel!
Hey not to worry, you're going to do great!
Thanks Grant. I nearly missed you kind answer.Hi Albert. They are 2 pieces of cherry glued together. I make the notches before I glue them together. Cheers Grant
Good morning Keith. It will be fun to compare the two kits. So far I am enjoying this project and I agree the CAF kit is well thought out and designed. From what I have read the Dockyard is a brilliant kit (lovely structural accuracy) and I have not seen anyone else start this build so it will be cool to follow your progress . Cheers GrantHi Grant. A very impressive kit and you are making a great job of it! l´m so pleased you are enjoying this project. The kit looks like it differs quite a bit in design and construction but the ultimate result will obviously be a beautiful model of this great ship. My limited experience with CAF Models has been nothing but good and Tom is a very clever designer and very helpful if you have any issues. The very best of luck with this excellent project. I will be following along with great interest and if you don´t mind, we can compare notes and differences between our 2 kits.
Besrt wishes Keith
Lovely solid cradle there Grant. Now the real fun begins. Looking as if your Enterprise is settled sweetly in there.Good morning. My swear barrel has been emptied and my little challenge completed.
View attachment 510479View attachment 510477
Building this jig was a mission. Took about 12 hrs. The issue is the slots are all just too small and you have to sand each one open so the corresponding joint fits in….
Then the pictures on the instructions don’t give a sequence of which sections get placed in the base when. Get this wrong and some of the other “stantions” don’t fit in place later. So you have to remove what you did and redo after more head scratching . Removing these is a mission because I kept the joins tight so it all will be super strong when done..
Anyway it is almost done, very sturdy and my center timbers fit in perfectly..
I put pins all around the upper section so elastic bands may be attached to keep the frames tights against the upper slots.
Cheers Grant
A solid base with a nicely fitted timber, Grant. And some Ferrari’s watching in the background.Good morning. My swear barrel has been emptied and my little challenge completed.
Cheers Grant
Hey Grant.Good morning. My swear barrel has been emptied and my little challenge completed.
Cheers Grant
With the contemporary drawings and the contract getting exact locations it is not as difficult as some others we have all seen. Your method of marking out before hand definitely works if all the frames are perfectly placed, but I have had better luck marking out the line of the clamps after all the frames are erected and faired inboard and outboard. This may just be me, go with whatever is most comfortable. I mark the outside of the frames and attach temporary battens in between the frames for the clamp to rest on while being glued in place. It takes a bit of math, but given the deck heights it is pretty easy to do. From the contract for the deck heightsIn reality, the CAF model is "harder" than the Dockyards because you need a lot of experience to figure out like deck placement etc., whereas the Dockyartds model seems to have all this stuff figured out for you.
Hi Neil. Freak it took a while to make but it is certainly solid and is pulled up to ensure the verticals and any angles are correct and will not move. She did snuggle in rather nicely. Cheers GrantLovely solid cradle there Grant. Now the real fun begins. Looking as if your Enterprise is settled sweetly in there.
Exciting.
