HMS Enterprise 1774 POF 1:48.
Perfect arrangement, Grant. All that's left to do it sand the char off 5000 pieces...you're almost done.
Good afternoon Paul. Thank you and I really hope it is at least close enough to perfect. Yes - char removal is not my favorite function. o_OSleep.I am removing the char where it will affect the look of the model and I still have plenty to do. The remaining char will be slightly sanded to ensure the PVA glue gets into the wood sufficiently for a decent bond. E.g the notches where the frames slot in. Lazy, maybe, however let’s rather go for efficient ROTF.Cheers Grant
Good morning.
I don’t know if I am being too cautious with this project. I am removing the char “only just” as my logic tells me rather have the inconvenience of hours of sanding VS the “OH cock” I took too much off. ROTF
As I make each frame I am dry fitting it on the keel before the jig gets made around it.
Each notch needs sanding.
Check that the frames all fit nice and snug.
I think (I am certain about nothing with this project) I am going to make all the frames, cant frames, hawes timbers and transom structures and dry fit before I make the jig.
I can see it being awkward to sand certain notches etc once the jig is made around the center timbers. Again I am perhaps being over cautious but why rush it?
OH boy I can see days of sanding ahead…..o_Oo_O
Cheers Grant
Wise decision. Any gamble could cost an hight price. Nevertheless, a quantum of relief always comes with the comfortably awereness about the possibility of scratching whatever part you should ruine. Perfect job so far, anyway!
Cheers!
Cheers!
Good afternoon Albert. Thank you kindly…I hope it is a perfect job so far as I will only find out when I put it all together ;) . I am feeling pretty good about it so far and most importantly I’m have fun playing with this.
Hi Grant, have you tried the metal mesh (kitchen) which is very effective to clean?Frank
Hi. I've tried for myself and I can say it doesn't work at all.
I simply have it from my own experience.Frank
Hi Frank. I will try it as I do find the Cherry a difficult wood to keep clean. Thanks
Thats a great Idea, it will pay dividends as you go along. My personal rule of thumb is sand the joint till the piece fits firm not tight.
Good afternoon Daniel. It is taking some time and besides frame 8 (which is a bit wobbly) I am getting firm but not tight. Frame 8 was the first do I probably was a tad overzealous. Cheers Grant
While I am posting I may as well show my progress on the hawse timbers. ( I got bored making frames…ROTF).
Note for future CAf builders: always label each part before using them. I had to go back and replace each part back in the frames and label them.Sleep.
The Hawse timber parts and little jigs ; One can see the bevel lines provided by CAF- very cool.
I beveled each part and glued them together in the jig.
F9438F74-532E-46FB-8234-4C740CE642BB.jpeg284626A7-7ECF-419D-8D3B-0E20FCA2B856.jpegD4DA165B-5C35-4819-B643-20D757C61D98.jpeg
Again taking “just enough” char off.
Preliminary sanding is done while the timbers are still in the jig. Again I have left plenty of sanding to do once the cant frame is made first. This way I can judge more carefully the final sanding requirements so the hawes timbers will fit snugly onto the first cant frame. …….that’s the idea anyway ROTF.
B6293873-A96B-4B7D-86BF-C8B2379B0740.jpeg6CBCAF9A-4D6B-4194-85B9-0BDF911A6773.jpeg9D753298-4A76-4896-8077-346697AD4EA2.jpeg
Cheers Grant
View attachment 508205View attachment 508206View attachment 508207
View attachment 508224View attachment 508223View attachment 508222
Cheers Grant
great job Grant
Cheers Grant
That jig for the hawse timbers is the BOMB! I had already started over three times by the time I got to where you are right now. Cool!
Cheers Grant
Very nice Grant. Those bevel lines etched into the frames are a real time saver. My Bluenose had em etched on both sides so one could fair the inside hull as well. However, the Le Requin only has em on the outside only and they tell you draw your own on the inside based on the outer ones!!
I took a couple of cups of coffee but I worked my way from the beginning of your log to the present. I'm facinated by what you are doing. I never realized the amount of work required for these type of builds.
Jan
That's true. Now immagine the same operation on bollard timbers e hawse pieces with no jig at all... . I had to cut out even the small notches machined in the plywood in order to get the correct air space between the sternpost and the bollard timbers... . This kit definitely looks far better... or easier under this respect, at least.1742311040333.png
Cheers Grant
That is looking very nice, Grant. A great view in real 3D.
