HMS Enterprise 1774 POF 1:48.
For taping the frames, I was going to put a sheet of acrylic over the plans and tape the frames to the acrylic sheet. That way I can keep the plans. I could also use a photocopy...
Hi Jack. CAF definitely spoils the modeler by giving us predetermined bevel lines. I must say I am enjoying this kit so far. Cheers Grant
Be sure the copy machine you use gives an accurately dimensioned copy. Many are not set up correctly and could be off enough to cause you problems. Even when I have used an architectural copy service I drew a scale EXACTLY to a given length on the original to be copied. Once the first copy is made, I measure the scale on the copy with calipers. I was amazed how far off the first copy was on several occasions. Luckily the techs made adjustments and got everything perfect after a couple trial runs.
Looking very neat and tidy Grant. Great work.
Good morning Niel. Thank you very much.....I hope it stays that way :D
Love your progress and your decision making on the pre-sanding. The amount you left on is perfect and the final fairing will work out, once you get everything in place! I'll await all your progress reports!
Hello Brad. Doing this for the first time it is a bit of a hit and miss as to how much pre sanding I do, so it is good to get your message. In my mind I am being a little conservative in my approach with my logic being I would rather have to sand more later than taken too much off and have an irreversible mess up. Cheers Grant
really? I didn't know that. Thanks for the heads up.
Happy to help Jack Sparrow
It is not every machine and the inaccuracy might be slight, but if it is something to consider. Also, I forgot to mention it is good to make the scale that will be checked in both the X and Y dimensions. A 5 or 6 inch is a good example as my calipers go to six inches.
Of course if the plan is one from past centuries there is also the potential that the original drawing has changed dimensions in one or both directions Luckily they usually have a measuring rule of their own at least in the X direction that can be checked first and sometimes adjustments can be made
AllanKP69 is definitely a bright beacon here on SOS. Isn't he?
Oh! Hey Grant, I am so glad you mentioned your Enterprise build on my Le Requin. I would have been distraught had I missed your first POF build. It looks like you have a great start with the keel, like Paul says be as accurate as you can get, these POF's as I found out the hard way tend to be very unforgiving even of little mistakes. Anyway, I'm here for the duration, good luck my friend.
Good morning Daniel. I’m super happy to have you on board. We will journey together with our two builds- will be fun. Cheers Grant
Good morning. I did some preparation work on the keel and centreline timbers. To ensure these lie perfectly in line and there is no movement in the jig I place 3 nuts and bolts into the keel. These go through the jig base so it is all secured nicely.( RED ARROWS) It is also important to place these where you are going to present the model on its stand.
I was extremely happy to see that all my notches lined up perfectly with the markings on the jig (BLUE ARROWS)
The keel will have to come off the jig when my parts arrive from China for me to build the rest of the jig. There is also a whole pile of sanding and cleaning up to do on this out of the jig.
8301E7D3-F6C3-4B0D-B698-C86CAF11A4E2.jpeg3820A721-2E12-4173-8031-FDA49E85B43F.jpegA23B850F-12DC-484B-8027-BCC269E32246.jpegBF3B6DAD-0E3D-40F4-B20B-A5FC8AB5D0EB.jpeg394F54B0-8FD1-4BC0-B2F6-FE3C40F4E3C8.jpeg
Cheers Grant
View attachment 507351View attachment 507350View attachment 507349View attachment 507348View attachment 507347
Cheers Grant
Well done Grant
Very nice job
Cheers Grant
A nice and solid base and alignment, Grant. It can't be better to start.
