Boom goes the bomb!
Hi Allan. I had to have a chuckle - I don’t think I will be doing to much kit bashing with this kit. I’m just going to try a build a POF model reasonably well. Cheers GrantThanks Grant. So some kit bashing if we want to have the figurehead as in Marshall print.... Oh well.....
Boom goes the bomb!
I don't think you messed up. From the looks of the timbers in the jig, you had the choice of making the tops of the timbers flush or the bottoms, but not both. I would have picked the tops as well. It doesn't look like there was enough meat at the bottom of those two (and some others) to begin with.Even with a “BOMB” of a jig I still messed up two timber bevels.
I did the same thing. No one noticedonce I work those little triangles we won’t even notice
Good evening Russ. I agree, it’s not a mess up….more like I got everything seemingly perfect until they had to be put together. There probably was enough meat and I just took too much off, even tho I thought I was being conservative. I’m actually very happy with the outcome so far but it is early days. Cheers GrantI don't think you messed up. From the looks of the timbers in the jig, you had the choice of making the tops of the timbers flush or the bottoms, but not both. I would have picked the tops as well. It doesn't look like there was enough meat at the bottom of those two (and some others) to begin with.
Good evening Paul. You mean you are only human after allI did the same thing. No one noticed.
Good evening Daniel. We should make those guys walk the plank at least.Ha, those little 'Jig Gremlins' like to jump out of nowhere and laugh they’re a.. off at you, I will have one coming up in my next post too!
I really like how it's turning out!! I'm already looking forward to when I start assembling my frames by keel)))Good afternoon everyone.
What I learned from reading every build log (completed or otherwise) is that everyone built the hawes timbers out of the jig. No instructions and this seemed logical so I went for it.
The first cant frame and hawse timbers. Prelim sanding done but I will wait for all the frames to be done to finalise the sanding.
Even with a “BOMB” of a jig I still messed up two timber bevels. I have cut and inserted a rectangle filler wood piece - I will trim and sand these when glue is dry - will be awesome when doneRED ARROWS.
View attachment 508672View attachment 508673
To ensure correct fitting I use the C section of the jig :
I had loads of fun and pretty happy so far….holding thumbs.
Cheers Grant
Perhaps not ‘conforming the rules’ but the outcome with all those curves fits very nice in the jig, Grant. Have confidence in your own skill and you really gonna love this type of build.Good afternoon everyone.
Cheers Grant
Good morning Peter. Thanks for your vote of confidence. This jig once built has very little room to play with (probably a good thing) but I couldn’t see how I could make these Hawes timbers and first cant frame in that small space- my outcome appears good however we all know what “appears” didPerhaps not ‘conforming the rules’ but the outcome with all those curves fits very nice in the jig, Grant. Have confidence in your own skill and you really gonna love this type of build.
Hi Grant,Good morning Peter. Thanks for your vote of confidence. This jig once built has very little room to play with (probably a good thing) but I couldn’t see how I could make these Hawes timbers and first cant frame in that small space- my outcome appears good however we all know what “appears” did. Cheers Grant
Good evening Alex. I am sort of guessing a lot here. As fantastic as this kit is designed I am finding certain aspects difficult to bring together. The transom structure is also something which has me in a state of uncertainty as to how best to proceed. It is super fun however that concern of this could go totally “pear shaped” lingers long into the nightHi Grant,
I think you have the correct approach. I had a hard time putting those timbers in with the building rig in place. I wish I had done it the way you are planning.
AR
Hi Grant. Are those beams of solid wood? I can't guess from your pics. Thanks in advance! Cheers.Good morning
A very boring post: I am plodding along putting the frames together : 50% done of the “square frames”.
When I get bored of frames I cut out some notches on the beams. I don’t have any fancy milling machines etc so it is up to a chisel blade…..1mm deep (supposedly)
One thing I know is that I am going to be doing so much wood sanding and finishing on this model.
Cheers Grant
Very cool. Today I will start working on solid frames. It is always interesting to watch such work.Good morning
Cheers Grant
……… When I get bored of frames I cut out some notches on the beams. I don’t have any fancy milling machines etc so it is up to a chisel blade…..1mm deep (supposedly)
Cheers Grant
true story...A very boring post
Thanks Grant. So some kit bashing if we want to have the figurehead as in the Marshall print.... Oh well.....
