H.M.S. Enterprize 1774 1:48 - Modelship Dockyard by Corsair Build Log
Nowhere in the instructions does it mention the installation of parts E1-1 and E1-2. These go on top of the keel and have the slots for the frames. There is 2 of each of the parts, so I would imagine these should be installed 2 thick into their respective locations. Also, I believe these should be installed right before the stern deadwood and the photo etch parts are installed.
@Modelship Dockyard Can you verify this please as well as answer the question that was posted on Alex R's build about fitting the stern post into the building cradle?
Thanks
Thanks
Hi Corsair, you shall glue two E1-1 and two E1-2 together, then glue them onto the keel, and then install the stern. This was indeed missed on the instructions, I will add them on and update it. I will answer the questions of Alex in his post.
Thank you for your response and your continued support ! Having you able to comment in here is really helpful !
I've not forgotten you all. ROTF I have been spending an amazing amount of time looking for the parts for the first frame and also aging the brass photoetch that goes on the keel. :) It's surprising how long it takes to find parts when you have dozens of sheets to look through. I suppose it will get easier as I use the parts up. LOL. I believe I have located all the parts for the first frame (I'm starting with frame #1. Each frame is a dual frame and there is a total of 37 frame pairs. For the first frame there is about 16 pieces for the first frame not including the pieces that go above the gun port (which will be added later).
Thank you for the kind words. :)
Grant,
U are in good company building the °Admiralty° version. You will not have the interior decks and partitions and the framing is less complex, but it is a wonderful and demanding kit.... Unless you want to bash it ! You can follow the DM instructions and do the interior., It would be a great project..Ha Ha
Yet, the CAF model is challenge enough. and once you finish the framing and install wales, upper planks, etc., the ship will look the same. You will make a super model I am sure.
Alex R
Jeff,
You don't need to pull the top timbers that go above the gunports- they are put in a bit later.
If you pull them now, they will be loose and be lost ! I did just that, but found the lost piece.
Yes, it is like hunting pieces for a puzzle. My frame halves for # 37 are glued up. I just need to finish them. Took me a while to figure out the stagger..
I Plan to dry-fit them to the keel tonight or tomorrow.
Later today I'll start to pick pieces for frame # 36. I'll send pic later
Alex R
Jeff,
Alex R
Thanks. Yes, I found them but left them in their sheets.
