Le Requin-Zebec-1750 POF 1:48 (ZHL)
Not nearly as boring, tedious, or mind numbing as one might think. ROTF Applying a fast sand down with my Dremel almost to the reference lines takes out most of the char then file and sandpaper to fit. Once glued into the keel then just some minor sanding to fair out the frames, internal sanding for fairing is a bit more uncomfortable due to limited access though.
The Dremel is definitely your friend! ;) Finish with a file. I was able to skip sanding because a good file will leave a very smooth surface. Plus you will most likely do a little fairing when she’s all together anyway. ;)
Dean62 said:
A good file will leave a very smooth surface.
Yea I have been considering purchase of high end files. I own a cheap set and an intermediate set, both mostly unsatisfactory.
I’d just like to expand a bit on what Dean mentioned in his posts and your reply. While a quality set of files is definitely important, smoothness on the surface isn’t guaranteed unless you're using the right cut or grade for the task. Even a top-tier file like a Vallorbe (Swiss-made) won’t yield a smooth finish if you’re using a coarse or double-cut file where a single-cut one is needed. It's all about matching the tool to the job.
The cuts or grades on sanding files (also called teeth or file patterns) have a big effect on how they treat a surface, especially on delicate model ship hulls. Here's a quick breakdown:
Single Cut:
  • Appearance: One set of parallel grooves.
  • Effect: Smoothest cutting; removes material slowly.
  • Best For: Fine finishing, fairing subtle curves, final smoothing before planking or painting.
Double Cut:
  • Appearance: Crisscross pattern with two sets of grooves.
  • Effect: More aggressive; removes material faster.
  • Best For: Shaping rough surfaces, reducing high spots, or working on hardwood frames/bulkheads.
Rasp Cut
  • Appearance: Individual, raised teeth (more common on coarse files or rasps).
  • Effect: Very aggressive; can tear up soft wood or delicate edges.
  • Best For: Initial rough shaping, not typically recommended for model work unless you're sculpting.
Cross-cut Needle Files (like diamond files)
  • Appearance: Uniform texture, often used in metal, but good for wood too.
  • Effect: Consistent, precise cut. Great for detail work or touch-ups in small spots.
  • Best For: Deck grooves, rabbet lines, tight curves, or even deadwood shaping
Top-Recommended File Brands for Model Work: Vallorbe (Swiss Made), Grobet USA, Pferd (Germany), Corrady (Italy)
Hope this clarifies and helps
Single Cut:
Double Cut:
Rasp Cut
  • Best For: Deck grooves, rabbet lines, tight curves, or even deadwood shaping.
Great info!
I normally use Diamond files, except when I’m fairing the hull, then I use a smooth cut file. It’s a little slower, but I don’t have to worry about taking too much off and it yields a nice finish, that if being planked doesn’t need any sanding. The glue actually holds better on a filed surface than on a sanded surface. Something else to consider as well is adhesion if it’s a bond surface.
Thats great information Jim, thank you. I knew that you could get files at different levels of smoothness but had no more knowledge than that. Now I know what to look for. Another interesting idea I came across was ultrasonic cleaning of my files. I just have happened to purchase a decent one to clean up my airbrushes and it worked great on my older files. I always use a toothbrush for clearing the grooves as needed but this ultrasonic really cleaned out the grooves.
Having the fairing lines scribed in as a guide by the kit maker is a real plus. Having to guess at it is always frustrating. Even the pre- scribed lines are, at best, only a guide. Every different set of hands assembling a model will add up to their own inevitable compilation of error creep.
I found fairing a hull always requires some serious eyeball and adjustment.
I made a decision a while back to of course fully plank the port side but on the starboard side in lieu of total exposed ribs I will fashion a large window of sorts focusing on the mid-section only. I will still end up sanding out a finish to the fairing process.
Good morning, all. It's been 10 days since I posted an update, and this update is not particularly interesting other than to show some progress. I reached the ships midpoint with the frames securely glued down. The majority of frames so far do not need to be held in their upper slots with rubber bands as they are snug as it is without them. I will however secure all of them when it comes time to fair out the interior to prevent an errant slip out while sanding. Check it out.
Thanks for checking in.
Till next time hope you have a great time.
Congratulations! Now on to the next step x100+ which seems to be the way of this OCD hobby!
I must say, your workbench looks downright tidy and organized compared to mine. Thumbsup
Except he has a bunch of frames in a box that says "Memory Foam"... ROTF
of course, for right now, he probably has frames EVERYWHERE!
Your work looks great Daniel !
