Artesania Latina Anatomy of Lord Nelson’s HMS Victory Trafalgar 1805
Brisbane, Australia
Video #1 - Part 1
Hello to all my fellow modellers.
And so the journey begins. I’ve been looking forward to starting this model since it arrived on my doorstep in February.
But lets get the elephant out of the room straight away; this will only be my second wooden ship model. Now I can already hear some of the seasoned wooden ship builders saying “why would you choose to take on such a long, complicated and challenging project when you don’t have the experience of this side of the modelling genre”. Indeed without question I cannot argue with that point of view.
However I would like to clarify why I’m going to challenge myself and give it my best shot.
My wife and I are returning to my homeland in September as part of a European Holiday. A few days of that holiday we will be spending in Portsmouth visiting a couple of friends, so I thought that it would be interesting to take a look at the Victory in her dockyard home. I started looking at utube clips of the Victory under restoration when Mrs J said, “You need to build a model of that!” I said maybe one day and thought nothing more of it.
Imagine my surprise when the postman delivered a surprise retirement present. I’m absolutely certain she has no idea of the scale of the challenge now in front of me and probably I don’t either.
So I have the kit, I either look at the box for the next few years and I’m now in my sixties or I just give it a go.
Please feel free to correct my nautical terminology when I fail, I’m sure the odd left, right, back and front will slip in. Hey I’ve only just found out the navy don’t use crows nests. Isn’t education a wonderful thing!
Thrusters on full!
As you maybe aware there are no conventional printed instructions with this kit, AL have adopted a 80 plus set of utube videos to follow. I wasn't sure at first but after watching them all at least 3 times, some more! I think they are OK.
These are the glues I will be using, thin, medium and thick CA and my preferred wood glue.
Notice I have decanted some wood glue into a smaller bottle from the dollar shop as it makes applying a lot easier.
As I am using thick CA glue to assemble the keel I took the advice of another modeller and glued the parts on some baking paper.
There was next to no sticking. But I will be using the wood glue when time is not a factor or wood glue is more appropriate.
It's probably important to get the keel straight and square at this point so I'm working on a flat MDF board.
A long steel rule keeps things straight.
I believe that this point in a ships construction is called “laying the keel” and should be celebrated accordingly. Who am I to disagree?
I wanted to celebrate the occasion with an English Ale brewed in Victory’s resting place in Hampshire. But here in Australia English ales are limited somewhat. But I did manage to get a Kentish ale more than suitable for the occasion.
In a strange stroke of irony I am building the greatest fighting vessel of its era HMS Victory, whilst celebrating the occasion drinking an English ale celebrating IMHO probably the greatest fighting aircraft of ever made; the Spitfire.
I do realise the kit comes with a working base, but for the hull construction I thought I would make something a bit more sturdy.
Each of the bulkheads fits into a slot which in turn is secured with a peg type piece.
Nearly all the bulkheads come in 3 parts with a good area of overlap to glue.
The kit supplies 3 jigs to place on the top of the frames mainly for protection when all the frames are in place. But I thought
using them to help alignment may be worthwhile.
I used a steel rule once again to ensure the parts lay very flat whilst the glue set.
Note the use of an expensive modellers tool used to encourage the frames to set square. :rolleyes:
I followed the instructions and used rubber bands to hold everything together.
The fit of the bow parts was perfect, well done AL.
The only part which I had some trouble getting to fit was part RH7 which needed a bit of clamping. This was mainly due that this parts
needs to bend slightly.
Well that's as far I got on my first day and still lots to do on Video #1 :eek:
Thanks for watching
T
Nice work Tony..conflicted between the AL anatomy or Enterprize..two different builds , I know ..gotta lot of work ahead on the RC..waiting to see if the tariffs recede..kits will push to two grand.. .although I can get the AL here in US.
Yep strange times with prices at the moment. Thanks for the kind comment
Video #1 - Part 1
Thrusters on full!
Thanks for watching
T
Tony, good day. I want to wish you success in this difficult task. The project is not simple, but I see that you have enough optimism, it helps. I can recommend Longridge's book "The Anatomy of Nelson's Ships". It has a lot of useful information about this ship. Here on the forum there are many assemblies of this model. Look at them. And success to you
Thank you Alexander. Yes I am very optimistic, but I will not get over confident. I simply want to enjoy the build. I recently got Longridge's book for my birthday and agree so much information.
Regards
Tony
Video # 1 - Part 2
Hi
Well that's video #1 complete. Yesterday and some of this morning was spent completing the skeleton and installing the many sides of the cannon ports. The parts defining the cut out on the starboard side definitely benefited from being wet before installing as it's quite a bend. I just noticed today after signing and dating my base board that the date I started was May 4th, Star Wars Day. I hope the Force is with me. :)
Thanks for looking
T
One of the doors
Hello Tony,
that looks really great. It's great that you're tackling a kit like this. It's certainly not easy. But it gives you a wonderful insight into this ship. I also bought this kit and I'm going to build it after my Athena. However, I will use it to build the Victory from 1756, as Thomas Slade had planned. It will definitely not look like the 1805 version.
I have drawn my chair and will follow your building protocol and learn from your experience.
Good luck and best wishes
Günter Ship-1
Only a few days, and it already looks like a ship! That's quite rare with most kits and builders. Well done so far. I too have attempted kits far beyond my experience, but when you realize you only work on one piece at a time, it isn't so overwhelming. Keep up the good work!
Have been following your comments on Alans build, now I get to follow your build as well.
Congratulations on a bold choice, I will eventually get to this build much later though.
Also bought “The Anatomy of Nelsons ships” just like lots of you. Fascinating reading.
Good luck Tony
Thank you. Yes breaking the build down into small steps helps.
Regards
Tony
Good luck Tony
Thanks Dennis. Yes great book, I got it on Alan's recommendation too.
Regards
Tony
I'm impressed! That's a lot of work completed in one day. The rest should be a walk in the park.;)
Video 2 Complete
Hi everyone
Started to plank the inside of the hold.
The cut out side showing the planking going just above the edge. This will need to be sanded flush later.
Some filling required around the cutout housings.
The kit provides a wooden template to mark the positions of the 8 ribs. More on this later.
There is also a paper template to mark the positions of what I believe are the base of the main mast and the pumps.
Back to the ribs. Although the wooden template provided allows you to accurately marks the positions of the ribs I had a better idea.
I had read a post somewhere by another modeller to use the Orlop deck as a guide to ensure the ribs extend through the gap correctly, this seemed like good advice to me.
But it struck me that I could utilise the wooden template as a second guide to ensure the spacing was correct. All I needed to do was glue in the first rib, using the Orlop deck as a guide. Then as I went along adding the ribs I kept locking in the wooden template along the top of the keel.
Here you can see the second rib in position, the Orlop deck ensuring the top is in perfect alignment and the wooden jig ensuring the spacing is correct in the middle. Not sure why AL don't suggest this.
This is why you need to be accurate here there is no room for error. Any misalignment will give you heaps of pain when fitting the Orlop deck.
The completed ribs in place.
The hold stained using the AL #6 Oak stain.
Thanks for watching
Tony
Hey Tony,
It looks really great and you're doing a very precisely. Great! The tip Abort the Orlop Deck for positioning the frames is really great. I'll definitely Jeep that in mind. I'm always happy to See your progress and great pictures.
Best regards Günther Ship-1
Video #1 - Part 1
Thrusters on full!
Thanks for watching
T
Excellent choice of refreshment - glass too Exclamation-Mark :p. Whatever happened to 'XXX'Question-Mark
