Thanks Dean.Great to see the frames going on the keel Daniel. Looks very promising so far!![]()
Good morning Daniel. As we say “good thinking Batman”. It is always good to watch you build as you make sure you “cross your T’s and dot your i’s”. A good example for the rest of usGood morning, all,
I have just a little more progress to show. I began setting the stern ribs to see how well their deep vee design was going to fit. I made sure the bottoms were seated all the way down into the keel/stern post but had no way of knowing if the tops of the ribs were actually sticking up the correct amount. I had heard from other builders that the stern ribs were problematic like the bow pieces were. So, I measured off of Ancre's plans which are identical to ZHL's but much cleaner the distance from bottom of keel to top of rib and sure enough my rib sections are anywhere from 4mm to 13mm taller than the plans. If they have to be off, I would rather be too long than short. I had been forewarned that the keel has a strong tendency to rise up off the floor bed as you glue down each rib and it certainly does with mine as well. Obviously, you cannot achieve accuracy on any aspect of the build with a keel out of alignment, so I focused this update on the hold down shims for future builders' consideration. First the stern ribs and height measurements off the plans.
View attachment 518899View attachment 518900
Here are close ins of the keel hold downs. It's amazing but there is enough tension in the ribs against the jig that makes the keel want to rise vertically.
View attachment 518901View attachment 518902View attachment 518903View attachment 518904
In the next photo I closed in on these little shelfs that stick out of every tenth rib. They proved support for certain bilge ceiling and clamp planks for interal support. Had I thought ahead I would have left them out until I faired the inside of the ribs, now they are just in my way. I may map the shelf and clamp strakes and just grind those little supports off???
Well for now that's my story and I'm sticking to it.
Thanks for checking in hope you all have a great weekend.
Thanks Grant, the challenge here is not to catch the tops of these fragile frames while working around them and snap em off. I've accidentally plucked a couple of em pretty hard but nothing broken yet.Good morning Daniel. As we say “good thinking Batman”. It is always good to watch you build as you make sure you “cross your T’s and dot your i’s”. A good example for the rest of us. Looks like a challenging project with some fragile frames, but is a peach of a ship. Awesome work. Cheers Grant
Thank you Günther, glad you could join in.Hey Daniel,
Wow very nice work. It looks like beautiful.
Regards Günther![]()
. They owe you...
More useful stuff, thank youI'm getting close to a milestone here, all heavy char has been removed from the frames, still a lot of finish sanding to go. In my last post I mentioned the little triangular tabs sticking out of every eleventh frame and I decided to map them out so I could grind them off making internal fairing so much easier. My method of using masking tape should allow me to map the original location back to the frames. Check it out.
View attachment 519976View attachment 519977View attachment 519978View attachment 519979
There is still quite a bit of mottled coloration on the installed frames which I intend to sand out during the fairing process. The pieces on the table still need a lot of sanding prep before I glue them into place.
Till next time, thanks for looking in.
Yea wouldn't it be nice to get an advertising fee; they are great files though, worth the cost.Nice product placement on the Grobet files. They owe you...
Your welcome Smithy.More useful stuff, thank you
Thanks Peter, they should be able to put me very close to the original positions.Very clever use of the tape for reusable tick strips!
Hey Johan, I'm glad you found my build here. Progress is coming slow as I plod through the dechar/sanding process. I'll actually be covering most of the framework but allowing limited internal views from the starboard side (thinking long oval viewing window) and maybe a removable deck portion. The wide expanse deck and all lateen sails are the main attraction for me.Hey Dan,
Just found your Xebec build log. It appears as if the Bluenose char removal exercise got you hooked on this action...
While looking familiar in terms of parts, frame and jig build-up, I'm guessing the Xebec presents it's own set of challenges, so I'll tag along for the ride.
Johan
Good morning DanielI'm getting close to a milestone here, all heavy char has been removed from the frames, still a lot of finish sanding to go. In my last post I mentioned the little triangular tabs sticking out of every eleventh frame and I decided to map them out so I could grind them off making internal fairing so much easier. My method of using masking tape should allow me to map the original location back to the frames. Check it out.
I became rather passionate about thoroughly disliking char removal after frame four... It was a very time consuming task.Hey Johan, I'm glad you found my build here. Progress is coming slow as I plod through the dechar/sanding process. I'll actually be covering most of the framework but allowing limited internal views from the starboard side (thinking long oval viewing window) and maybe a removable deck portion. The wide expanse deck and all lateen sails are the main attraction for me.
Will do Johan, thanks for the heads up.As far as you ideas about showing the interrior; it might be beneficial to look into the methods used by @janzwart and @Canoe21.
yup me too!
