- Jun 17, 2021
I heartily concur!thank you so muck Grant.
Thank you.Beautiful head work!
Wonderful Mustafa.I finally completed the supports. I'm happy with the overall look.
I installed the lower part of the bowsprit and the gammoning before closing up the bow, and even at that I could only install 1 gammoning because of lack of room.I installed the port side top head rail.
Yes Jack, I will not glue the grates in place before assembling the bowsprit and gammoning to avoid running into the same problem.I installed the lower part of the bowsprit and the gammoning before closing up the bow, and even at that I could only install 1 gammoning because of lack of room.
Looking good, by the way
Thank you Brad.Bow came together nicely Mustafa! Thanks for sharing your wonderful build.
In reality I should have done this a lot earlier that way I could have put two gammonings, like it's supposed to have... My mistake.rYes Jack, I will not glue the grates in place before assembling the bowsprit and gammoning to avoid running into the same problem.
Thank you so much my friend.Again, nothing but great modeling skills. What an impressive build Mustafa.
