Looking great Daniel. Clever solution on the mast.
**VIEW THREAD HERE** |
Thanks Dean!Looking great Daniel. Clever solution on the mast.![]()
Congratulations, Daniel!Finally reached my full rib installation milestone. In addition to endless sanding, I've concentrated on the ship's transom area, the future taffrail will set further back on top of the grated decking area. First an overall of the completed ribs.
The following transom area has been a tough challenge, first just trying to visualize exactly how the pieces go together. Then reading from translated Chinese and looking at the very poor-quality pictures in the printed instructions was kicking my rear side for several days. I then remembered this kit came with a CD which when I opened, it contained the same set of pictures but in fantastic high dpi quality which enabled me to go ahead and start dry fitting all the pieces I had cut out and prepped for install. It became necessary to remove small portions of the jig (you can see fresh cut plywood areas) to facilitate the assembly. The rest of these photos are a process pectoral HA! I am building up my pecs. Lets try pictorial.
View attachment 522519View attachment 522520View attachment 522521View attachment 522522View attachment 522523View attachment 522524View attachment 522525View attachment 522526
For ease of access a homemade lift.
And some final photos.
View attachment 522528View attachment 522529View attachment 522530View attachment 522531
I lost count how many times I'd file a little then test fit repeat until it works and looks good.
Well, it's back to the sanding dungeon, I sure thank you all for checking in.
Till next time.
Thanks Paul. How about your next project, are you researching anything yet?Congratulations, Daniel! A major milestone for you!
Thanks Peter, I don't know about record time, it seems like a long time already but that's just how sanding char ribs goes.Wow Daniel, putting in the hours! Lovely work, in record time!![]()
Thanks Jeff.Absolutely beautiful !
Hi Günther, thanks for the complements. The red clips came from a chain craft store here in the US called Michaels (very similar to Hobby Lobby). They also had some miniature clothespins; these little clamps are handy as a shirt pocket.I saw these red clips in a picture to hold the frames in place. May I ask where you got these clamps? Ebay, Amazon?
Thanks Grant, Sexy indeed she has a fine wide body!Excellent, that first photo already looks sexy.
Thank you so much Shota!Congratulations, Daniel!
A beautiful milestone for you!
I started working a bit on something but I'm not sure if it will work out so I haven't really been taking photos. I also have some new shop tools I have been on-boarding. All of this to say that I may have a new build report started eventually (or not).Thanks Paul. How about your next project, are you researching anything yet?
Hmm... sounds suspiciously like a design and construct project???I started working a bit on something but I'm not sure if it will work out so I haven't really been taking photos. I also have some new shop tools I have been on-boarding. All of this to say that I may have a new build report started eventually (or not).
Hmmmm I’m with Daniel here Paul …, very suspiciousI started working a bit on something but I'm not sure if it will work out so I haven't really been taking photos. I also have some new shop tools I have been on-boarding. All of this to say that I may have a new build report started eventually (or not).
