www.shipworkshop.com
Thank you Y.T. . But i am looking "the toy" ...HAHAHA . I really appreciate the link. I was looking them, but failed.Better buy this one. It will last. Syren things made of wood with no steel ball bearings is a toy for a few applications. Then throw away.
SM4 series serving (wrapping) machines | ShipWorkshop.com
All-in-one machines for any jobs where one rope winds around another. (Check this video on YouTube for how to assemble it. Turn on subtitles.)(Basic operations on ShipWorkshop serving machines. Starting from 7:23. Turn on subtitles.) Serving machine is intended for: serving ropes, making...www.shipworkshop.com
Very interesting design. Simple, not expensive and will cover all my needs.Sorry. I may had misunderstood. You meant a rope walk meaning a rope making machine. Then I would recommend this machine. I use it all the time. I give it 5 stars.
Rope making machine. VR. Vertical type. | ShipWorkshop.com
Simplest, fastest, easiest, compact, no skills needed, instant results. It is a small but powerful tool for making professional ropes for your model. (Check this video on YouTube for how it works. Turn on subtitles.) The VR Rope making machine, ropewalk, is intended for making professional ropes...www.shipworkshop.com
Great !!! Thank you for the picture !!! Watched the online video too. Is very simple. Like it too much. Will order one.This one is hanged up as high as you can in your room. Rope is being wound up in vertical position. You hang some weight at the end of the rope. The motor is included.
If I remember well, I saw a video where the pound aideis block by a small restrictive object to not allowing counterrotation during the rope making process, then the restriction is removed AT the END of process and the pound counterspin thus stabilizing the rope before used.Great !!! Thank you for the picture !!! Watched the online video too. Is very simple. Like it too much. Will order one.
Last question: when it finish rotation, and you remove the weight, the rope it done, does not untwiste when you start to use it ?
Thank you !!
Thank you Y.T !!!No reason to worry about rope untwisting. Just let the weight to wind as much as it wants. When weight stops rotating you burn the upper end of rope with lighter or a match (I use polyester yarn only). This secures rope end from untwisting. Note that newly twisted rope of any material (steel wire, polyester or cotton) wants to untwist. This is why the end of any rope must be tied up to prevent this.
Thank you !! . I solved my problem, for ~ $45 more I ordered the one suggested by Y.T.
Thank you !!! Unfortunately I searched youtube and can't find any author call Kudin. I used diferent keywords associated with Kudin (Model ships, ropes, part 3 , etc) and nothing.I Found the video source for my precedent post #9 : See Kudin vids on YouTube, with Rope part 3 on the title. Sorry, have no link with my phone, I was not able to copies IT. Hé used the vertical ropewalk.
Ok... I was able to find Kudin's videos. But now I can't find the way to translate the video titles.I Found the video source for my precedent post #9 : See Kudin vids on YouTube, with Rope part 3 on the title. Sorry, have no link with my phone, I was not able to copies IT. Hé used the vertical ropewalk.
Let me time to Search from a pc, i Will find IT today.Ok... I was able to find Kudin's videos. But now I can't find the way to translate the video titles.
OK, I found it : Kudin Vertical Ropewalk
This guy have a lof very valuable videos.
