Yeah, This guy is a perfectionnist
Edit: mispelling guy by gut. Hoping this was not an offence in english.
I can't see why that would be an offense. Beside, it was very clear it was a typo.Yeah, This guy is a perfectionnist
I agree. He have a lot of videos covering all the process of building more advance ship. I think que can highly recommend him, like Olha and couple of others masters here in SoS.I can't see why that would be an offense. Beside, it was very clear it was a typo.
I have now watched a few times the video and understood why the guy was using such an amount of weight. And yes, he is a perfectionist. Open a few of the other videos and his job is truly amazing. Done by him everything looks pretty easy. But they aren't. Amazing skills he has.
Cheers
Daniel
Just a short little comment: for the cost the syren ropewalk is outstanding. I have done all my rope with it (likely few miles) and still going strong. I have zero issues with it except for the gears that would be better in hard plastics or even metal, maybe the noise could be improve that way. But I will be more expensive obviously.
Thank you !!!There is a great tutorial here on SOS to make rope. It explains also how to avoid untwisting rope and what to do. I can cut my poly rope and don't have to seal it to avoid untwisting. It keeps in shape.
go here: https://shipsofscale.com/sosforums/threads/make-your-rope-on-a-rope-walk.9094/
The priciple is over 2000 years old. There is no copyright on that machine.(don't want to copy exactly due to copyright infringement).
Yep I followed Steef66 tutorial and copied as best I could plus some modifications to better suit the area I would use it in. Fantastic Tutorial, Highly recommended.There is a great tutorial here on SOS to make rope. It explains also how to avoid untwisting rope and what to do. I can cut my poly rope and don't have to seal it to avoid untwisting. It keeps in shape.
OH sorry! I did not realize that. Let us know how the vertical ropewalk work, I'm curious. Now, we will need to look for house with 15 feet ceiling (Joking).
I'm reading this and my opinion about you is that you have no clue or experience with this. What you said here is impossible or at least not to do. Nonsense. You can only make vertical rope if the strands hung free. It doesn't work like horizontal ropemaking with a splitter cone. Vertical is the easiest way to make rope, but limited.Ceiling height should not be a limitation with the ShipWorkshop VL vertical planetary rope spinning machine. The length of the vertical rope can be increased to any desired length by running it over a sheave or through a block or multiples thereof with the weight at its end. In that manner the vertical rope can be made to turn 90 degrees and run horizontally and then to turn 90 degrees again to the vertical or be made to turn 180 degrees upwards to a block or sheave and then turn 180 degrees down again, with the weight at the end, and so on. It may take some experimentation with the amount of weight to apply, given that the longer the length of the laid-up rope, the more it may want to stretch. Full disclosure: No, I've never done this myself. (I have the PL4) I have, however, seen pictures of such arrangements.
Visiting MSW is not necessary, we have here a great tutorial where all ropemakers shared their experience.
The explanation is fine, but the tale is false. Don't tell me anything about manners, then I won't tell you anything about good reading. Because then you would have already seen that link in my previous post. Yes we Dutch are sometimes very direct, but we also understand very quickly who or what we are dealing with. So far you only full of bullshit.Would you be so kind as to provide the link to it. Just a tip for future reference: I understand that it may not be the custom in the Netherlands, but here in the United States, it's considered good manners to provide a link for the readers' convenience when referencing another site online.
You can find the Syren ropewalk here: https://syrenshipmodelcompany.com/ropewalk.phpI agree with you, but you can't find any Syren ropewalk at all. Now I ordered the vertical ropewalk posted here. Lets see how it works
"sometimes"??? I am Dutch and I am "always direct". My wife has gotten used to it. We tell it like it is. NO beating around the bush, or flowery language. It may sound arrogant but is not meant to be. Sometimes when I am direct, I piss people off, but most of the time people are ok with it. Little shocked, but then they know I am not BSing around.Yes we Dutch are sometimes very direct, but we also understand very quickly who or what we are dealing with.
Nice, it's back in stock. Unfortunately, I have now bought the Hanging Rope Walk. Thank you !!!You can find the Syren ropewalk here: https://syrenshipmodelcompany.com/ropewalk.php
