- Apr 12, 2025
What if one cannot sculpt, either?Hey, Jack, you forgot about clay baking, yet another option if you cannot carve or 3D print.![]()
... then, you're stuck with the one supplied in the kit, or simply buy one aftermarketWhat if one cannot sculpt, either?LOL
I think it is possible, but costly to obtained high resolution at the scale of ship model. There is a large range of quality in these 3d scanners.I wonder if a 3d scanner can do the job of capturing an image so that I can import it into a slicer program? hmm...
Got to be because you love doing it that way Roger. I was the same but took the plunge and learned to do 2D work thanks to Wayne Kempson a long time ago now, and happy for it. Saves on paper, space for a drawing table and easy to fix mistakes, (so saves on drafting eraser costs)I make all drawings including lines drawings by hand
Dave, I think you may be missing my point. At no point did I challenge your personal experience; in fact, I respect it. What I responded to was a broader idea I’ve seen mentioned often by some members: that scratch building is inherently cheaper. That’s where I felt it was worth adding some perspective, especially from both the scratch and kit-building sides, where complexity and tooling play a major role in cost.you got confused by the statement because you missed the point or choose to ignore the point
So asking a person like me i have to say scratch building is far less expensive and i repeat ASKING A PERSON LIKE ME like i said me i have collected a lot of tools and material, knowledge i never implied this is true for everyone
the post started out with someone starting in square one with one kit and the post ends with someone who has years of collecting tools and experience.
here only what you want to hear and disregard what does not fall in line with your ideals.
We are cycling in the loop: I get your point, you're speaking from a place of deep experience. You've got the tools, tech, and skills to make scratch building very cost-effective for you, and your breakdown makes sense in that context. But here’s what I keep coming back to: Why is it that in these comparisons, it's always a multi-thousand-dollar kit that gets used as the reference point? That’s an example of high-end, kit, not representative of the majority of what modelers are actually building, especially those just starting out or even those who build regularly.i get it Jim
maybe a better vs one to the other is if you bought a kit for $1,400.00 and i started the same model with just a set of modeling plans i think i can build the same model for a third of the cost. ONLY because i have a 3D printer and can design and print the cannons and fittings, i have access to an industrial laser cutter and a shop full of tools i collected over the years. plus over the last 60 years i have been building models.
So for me or other in my position can build models far less than buying the $1,400.00 kit.
take the same vs and ask someone building the $1,400.00 kit for the first time and asking them to copy the kit from scratch. chances are it would cost them far more because they DONOT have the tools and experience. buying the tool up front in one go would be expensive and no doubt double if not triple the original cost of the kit
in my opinion anyone coming in this hobby and their goal in the long run is to build ship models from scratch i would suggest jump into scratch building right at the start. Begin you journey small and with a limited amount of tools, just the basic will do. Then ship after ship build you inventory of tools and knowledge.
Dave, I appreciate your insights on scratch building and the encouragement to share techniques and experiences.just my opinion i believe scratch building should be supported and perhaps encouraged. Scratch builders should show their work, describe what they are doing and how to do it.
This should not be pushed on anyone or even suggest it is better it is just another road to follow.
if you satisfied building kit after kit that is fine
Putting scratch building out there is just showing there is more to the hobby and if you want to expand you interest then by all means go for it.
i see kits as a loop by its very nature it only goes as far as what the kit makers put out. Scratch building is open ended and there is no limits to your imagination or how a project id built.
scratch and kits both start the same. begin with simple projects and work your way up to more and more complex builds. buying only the tools you need and not what you want
Alright, Dave, I managed to find a sheet of basswood for $1.99 — not bad at all. But what about shipping? That could easily add another $5 to $7. And how do I know one sheet is enough? Maybe I’ll need two or even three. So, now what?Why is it that in these comparisons, it's always a multi-thousand-dollar kit that gets used as the reference point?
ok fair enough take the dory kit it started as $79.00 and i think it went down to $44.00 and on sale for $33.00
mind you there is more to the kit than just the wood like printed instructions etc. paint and glue and an exacto knife a printed box clamps all add to the cost. i am just using the basic dory as a build and not all the added extras
from scratch i bet i can build it for less than $10.00 and because i have enough wood laying around i could do it for nothing but my time.
even if i buy the wood it is less than $5.00
i think we were using hi end expensive kits to compare it to the cost of some basic tools
But the main question - whether I want to go this route? Why do I have to go this route, because you think it is better this way?i also think we were using the hi end expensive kits to show you can buy just about all the tools you need for basic scratch building for the same cost
