**VIEW THREAD HERE** |
the bumpy stuff is an iron on heat activated adhesive.Good luck finding 'that'! I had to buy a roll of 'edge banding veneer' off of ebay (Veneer Depot). It's .015" thick x 2.0" wide x 160' feet long, Maple wood. Cost $30 bucks. You can cut thin 1/16" wide strips out of this via a knife or one of those cheap office paper cutters/shears from Amazon. Maple was the only light-colored wood available. There is no adhesive on the back but there 'is' some sort of a micro-thin, bumpy clear film on the back. I guess that's for better glue adhesion. That film is so thin that there's no need to worry about it (I don't).
Hope this helps...
Check with Joe at Modeler's Sawmill.Anyone know where I can purchase(USA) some 1/64 x 1/16 or .020 x 1/16 basswood(or similar) strips ?
Thanks!
Nice job. quick and easy! How do you get the thickness of the trim?Ahaa! I made a thickness sander using a Dremel drill press and a drawplate for the back gauge. Cut the wood strips a bit thick on a small table saw then ran them through this gadget for final thicknessing. This redneck rig also holds tolerances around a thou. There are many ways to skin a cat like this, unless you don't want to mess with equipment!
Consider veneer. Do you have a Woodcraft near you?Anyone know where I can purchase(USA) some 1/64 x 1/16 or .020 x 1/16 basswood(or similar) strips ?
Thanks!
That bumpy clear film IS the glue. It’s hot melt glue and you use an iron to apply it.Good luck finding 'that'! I had to buy a roll of 'edge banding veneer' off of ebay (Veneer Depot). It's .015" thick x 2.0" wide x 160' feet long, Maple wood. Cost $30 bucks. You can cut thin 1/16" wide strips out of this via a knife or one of those cheap office paper cutters/shears from Amazon. Maple was the only light-colored wood available. There is no adhesive on the back but there 'is' some sort of a micro-thin, bumpy clear film on the back. I guess that's for better glue adhesion. That film is so thin that there's no need to worry about it (I don't).
Hope this helps...
I think there is one nearby. I will check them out.Consider veneer. Do you have a Woodcraft near you?
Do you have a source?Model aircraft plywood is available in fractional sizes the thinnest being 1/64”. At that thickness, the ply’s are invisible.
Roger
That looks awesome, Pete!Since my other hobby is model railroading, I've been using scale lumber from Mt Alberts in Canada. (They ship to the US). They are owned by Fast Tracks. (https://handlaidtrack.com) The lumber catalog is buried in their menu. They offer basswood in the various model railroad scales (N, S, HO, and O) as well as dimensional lumber. I buy their bulk pack in 16" lengths. I've used HO scale 1X lumber that is close to 1/2" thickness in 1/4" scale. Attached is a photo of a boat shop I built for a future Maine coastal theme model railroad layout. It is scratch built using Mt Alberts lumber.
Pete
