Nikitin San Bartolome 1584 A.D. (Kit #35)
Do you think the wrap around deck sides which i taped together are correct. Also how do the hinges go together?
Sorry, I can't help I've not gotten to that part of the build yet. I think if you do a search and find the other SB builds on SOS you might find an answer.
I used the same type of rudder hinge on my Willem Barentsz build.
Jan
That's interesting I was going to put the hinges on top of each other where you have butted them together.
Maybe not reading the plans the right way but Iam very confused with the belaying points as an example one plan show to belay rope Z17 on the belaying rack and the other on the mast cleat.Some have a number but no coresponding number on the plan for it.Any help would be appreciated.
Gerry, I’m not much help for your problem, my SB has been on the shelf for a bit. Maybe some of the other SB builders will be able to help you.
Jan
Jan
Thanks Jan I sure hope someone as been far enough in the rigging to help me.Getting frustrating since no more videos being produce to clarify the rigging.
I think at least one or maybe two SOS members have completed the SB build. They might be able to help you.
Jan
buenas tardes a todos:
me gustaria saber cuando pintais con los tintes de Pavel, si usais barniz,
como limpiais el aerografo o como diluis el barniz si fuese necesario para dar el acabado.
¿El barniz lo dais al final de cada trabajo?
Agradeceria todos los detalles posibles sobre la aerografia a tener en cuenta
con el acabado del modelo.
También me gustaria saber como se aplica el aerografo para el tintado de las velas.
saludos: Edorta
Good afternoon everyone:
I'd like to know if you use varnish when painting with Pavel dyes,
how you clean the airbrush, and how you dilute the varnish if necessary for the finish.
Do you apply the varnish at the end of each job?
I would appreciate any details you can give about airbrushing techniques to consider when finishing the model.
I'd also like to know how to use the airbrush for tinting the sails.
Regards, Edorta
