I also had some difficulties with the yard dimensions. In the end I based them on the sail size as much as the instruction sizes. Here what I used based on the best measurement that I could get off of the fully rigged ship (in mm):can you tell me the measurements of the yardarms, my kit is very vague. by the way your black pearl is real nice. You have good pics but i need the sizes
How did you attach the deadeyes to the tops (platforms) on the masts? I think I would use wire around the deadeye and then run it through to make loop where the plans say to put an eyebolt. Or should I use those long eyebolts and run them up from the bottom and attach to the deadeyes??I added the gun port covers. I initially installed a couple with brass colored hinges, but later removed them and put all of the hinges into Brass Black to take off the shine in keeping with the dark color scheme on the ship. I also added a rope to each gun port cover.
Next, I added the bowsprit to the front of the ship.
With the hull mostly done, I began working on the masts. I tapered according to the plans as best I could, but I ran into some issues with the sizes of the precut mast caps and trees and the diameters called for in the plans. I made a trip to the store for some more dowels of various sizes and I ended up with what I needed to make the mast parts according to actual pieces supplies in the kit vs. the actual dowels supplied. It also looked like I might not have the sizes I need for the spars, so I made sure I got (extra) dowel for the spars. I find getting spars correct to be somewhat challenging as you have to taper then from the middle to each end. I stained the masts dark walnut and the tops, trees and caps black. The wooldings were wrapped around the lower masts according to the plan and the rails added to the back of the of the tops. Note that the capstan on the main mast was slipped on before the top and wooldings were secured, otherwise it would not have fit right due to tapering of the mast.
View attachment 247858View attachment 247859
I assembled the masts in 2 sections so that I can place the lower masts into the hull and get the shrouds in place before adding the rest of the masts. The fit is tight enough that the upper portions stay in place as a dry fit. In the picture, the mast are just fit into holes and not yet aligned or glued.
Do U have the file pdf of the driftwood? I need it very much.. my instruction are poor.....As mentioned previously, I am a bit ahead of my posts in actual construction. I have started ratlines, but needed a break to do something else for a while. I decided to start going through the spars needed for the build when I noted a potential discrepancy in the plans. The upper spar (P. 50 on the plans) for the mizzen mast is shown as being 175mm. This seemed much to long to me, so I checked the sail plan as well. On the sail plan the square rigged sail (Sail 7) has a top length of 135 mm (as does the actual sail provided). The majority of spars are between 10 and 15mm larger than the sail sizes which seems appropriate to me. Therefore I plan to make the mizzen spar (P. 50) 145mm instead of the listed 175mm.
Has anyone else encountered this and am I missing something that will be a problem later if I only make the spar 145 mm?
View attachment 251131View attachment 251132
In any case, I think the sails provided are somewhat oversized for this ship. Maybe that is why the Black Pearl was supposed to be so fast?
I sent a direct message to you with a link. The only real difference in the lengths of yard arms was the mizzen topgallant. The plans called for 175 mm but I made it 145 mm to fit the sail more appropriately.Do U have the file pdf of the driftwood? I need it very much.. my instruction are poor.....
I sent you a direct message with a link to the information that I could find. I don't have the drawings that came with the kit any longer.Hi Jeff, sorry to keep this thread going as you're probably way past this model now, but I have the same kit without the mast, rigging and sail plans. Could you let me know the dimensions of the masts please so I can at least make a start. A copy (even photo) of the actual plans would be even better, thanks.
