- May 25, 2020
Nice work. Looks pretty massive, but a lot more "French" than the Dahlgrens, and better balanced than i had thought. But...i reckon Chuck will still be pulling his hair out (!) over bulwark stretching !I think this thing is about done. I need to stare at it for a while and see. I added the guy for scale and for the muzzle up at the level of his face, so I scaled the carriage down to the trunnion height of the 8 inch shell gun.
I rotated the carriage to set it on it's skids, so it should match the deck-camber better.
Well you've been busy ! I always did think her stern castle looked a bit odd, i will be interested to see what you do with it. I've been first planking one of my projects as well, prefer to do so outside in summer so i don't have sawdust all over the house (and avoid marital sea battlesIn the end, I got the first planking done. After sanding thoroughly and I mean thoroughly . . . .
View attachment 530862View attachment 530861View attachment 530860View attachment 530859
Here's the bow and stern after clean-up. And man were those little stubs of plywood a pain to sand flush. Also, I left the bulkhead extensions aboard until I finished the second planking.
View attachment 530864View attachment 530863
Pete! Thank you! I haven't built a lot of ships, but I think this was one of the most difficult because of the shape of the stern. Tell you what, though . . . that hull is super rigid and heavy! She's a big boned girl!Nicely done! I was wondering how you would navigate between the "Scylla and Charybdis" of fabricating a typical Mamoli hull!![]()
Jerry! Superlative! I love the result you achieved with the rotation of the carriage. I thought the Paixhans cannon-obusier of 80 No. 1 was a good sized gun and now I know for sure, thanks to you!I think this thing is about done. I need to stare at it for a while and see. I added the guy for scale and for the muzzle up at the level of his face, so I scaled the carriage down to the trunnion height of the 8 inch shell gun.
Gunther!Hey Jerry,
very well done. The planking looks very good. Keep up the good work.
Best regards
Günther![]()
And, having the Dahlgren let me see that my bulwark stretching plan would work - I figured the Paixhans gun would be smaller to some degree. So having increased the bulwarks from 3 to 5 feet (3/16s" higher) I'm confident that the guns will be pretty much square in their ports.Well you've been busy ! I always did think her stern castle looked a bit odd, i will be interested to see what you do with it. I've been first planking one of my projects as well, prefer to do so outside in summer so i don't have sawdust all over the house (and avoid marital sea battles! )
i have a question for you...how are the wheelhouses supported in the mamoli world ? I had decided on two crossbeams, fore and aft of the paddlewheels, and straight across the ship just below deck level for L'Aigle, but i can see no such structure for the moment ? Are there strengthening blocks built in behind the hull structure at these points ? Never having seen the Mamoli plans,I must admit that i am curious !
![Aide-mémoire_d'artillerie_navale___imprimé_[...]Lafay_Jules-Joseph_bpt6k9737980n.JPEG Aide-mémoire_d'artillerie_navale___imprimé_[...]Lafay_Jules-Joseph_bpt6k9737980n.JPEG](https://shipsofscale.com/sosforums/data/attachments/514/514792-41219f8dd9ba62237b127669ba0e47a9.jpg?hash=w6UFWCpoaQ)
JERRY!!!!!Stop the presses!
I was directed to more data that's significant here.
The above carriage appears in Aide-Mémoire d'Artillerie Navale Imprimé aka: Lafay as plate 10
It doesn't have a hole trough the carriage for the breeching, but instead had the sort of oar-lock fitting like American carriages have.
It says it's for canon-obusier of 22 rather than a canon obusier of 80; the 80 refers to a shot-weight of 80 pounds, but it had a bore diameter of 22cm, so I don't think it's referring to a 22 pound shot-weight; ie: same gun. I can, and will, adjust my carriage to match this drawing, but...
A little further along is plate 17.
This is a lower-slung carriage and will probably fit the L'Orenoque model better.
this actually looks very similar to the carriage used on the model of L'Aigle, rather than the plan version.(as photo above).Note the height of the tube next to the sailor, now that's much more like it should be
WIP image
A nice and solid basis for the second layer, Chuck.In the end, I got the first planking done. After sanding thoroughly and I mean thoroughly . . . .
Jerry! I agree. Much better proportions. Thank you for all of your work on this!Note the height of the tube next to the sailor, now that's much more like it should be
WIP image
Peter! Thank you!A nice and solid basis for the second layer, Chuck.
I did the starboard side first to experiment with how the planks would run. Because L'Orenoque will be in the same room with Harriet Lane, and because Harriet Lane is displayed port side out - the port side is the money-maker. Not that anyone but you and my Admiral will know because this heresy will be covered in copper.
