What glue is best ?
Hi guys , what glue do you find best for rigging and block tying ?, I've tried with superglue thin and to be honest I find it either goes everywhere or goes chunky and white ? Am I doing something wrong ? All comments great fully received
Hey Steve,
there can be various factors why the second glue turns white.
I would only use thinned wood glue for ropes and rigging. This does not turn white, but remains transparent. But as I said, you have to be careful with superglue.
Best regards
Günther Ship-1
I have had good success with white PVA thinned down. It takes a few minutes to dry, but works well and has bit more give with no staining like CA. Have not tried clear PVA as suggested above but will look into it as well.
Nitrocellulose based clear nail polish. It comes in a little bottle with a brush in the top.
Like a lot of materials that used to work reliably well, but are now on the "environmentalists' hit list," nitrocellulose lacquer is becoming more difficult to source outside of specialty retailers. The flammability of nitrocellulose is such that OSHA regulations now impose a host of expensive regulations on its commercial manufacture and handling. Nitrocellulose nail polish is still available, AFAIK, but is expensive and the out-of-the-bottle consistency of the nail polish is thicker than I prefer for fastening rigging knots. It is also high-gloss, so if a blob sits on the surface without soaking into the fibers, you end up with a shiny knot. When I used it, I would thin the nail polish by adding a bit of acetone to the nail polish bottle. At present, of my wife's reports are any indication, the trend in nail polish is away from the nitrocellulose-based lacquers and towards acrylics and what they call "UV-curing gels." Duco cement is still real nitrocellulose adhesive (nitrocellulose dissolved in acetone,) but It has to be thinned for brushing onto knots and isn't cheap anymore, either.
If it's real nitrocellulose lacquer that you are about, the luthiers still use a lot of it due to its tonal qualities. There are several brands, all of which can be sourced through lutherie suppliers, and some is even "satin" finish.
See: https://www.amazon.com/Solo-Guitars-Oxford-Nitrocellulose-Lacquer/dp/B0BZX1J1FM/ref=sr_1_17?adgrpid=1345802799182654&dib=eyJ2IjoiMSJ9.wxy1aZ2g9zDJC9oMW2TOLhl7v7G6eRLFi3HrYWYbaf-uuKmDVKI1ALvJfqagPBUAL-txpdZxCgD3nygjdx--BOp9FZ7km_8VxmMS0l9P5F09RDvRJamg3gK2RRuDwESlkXH35-TMNx6autWJMokFp07qlGfpt8OSA4htW3oJZAsJNi0wllrY0XSZ4WqU1rZ7.c2N6sPB2v5QG90o3zobbWLMjIfvJANacnTfgA-ivhh8&dib_tag=se&hvadid=84112998031788&hvbmt=bp&hvdev=c&hvlocphy=88716&hvnetw=o&hvqmt=p&hvtargid=kwd-84113025843009:loc-190&hydadcr=29646_14610018&keywords=nitrocellulose+polish&mcid=d050ee12575a31219025d2540f562b1b&msclkid=91c0551276f918de037e3d7cc9e7c325&qid=1752088477&sr=8-17
Nitrocellulose has the advantage of being more or less easily dissolved with acetone, so, if necessary, knots secured with it can be untied. The only other material I know of that can reliably be dissolved easily is shellac. (In theory, PVA can be dissolved with isopropyl alcohol, but, in my experience, not that easily.) Since I use canned clear shellac extensively as a sealer, I have gone to using it for fastening rigging knots as well, primarily because it's handy and dirt cheap, but also because it soaks into the fibers readily, dries invisibly, is less noxious, being alcohol-based, and dissolves easier than anything else I know of.
That depends on the rope you use. Cotton likes diluted white wood glue. And polyester rope responds best to thin superglue. I have a fine sewing needle to apply the glue. I inserted the needle with the pointed tip into a wooden rod to create a handle and I cut the eye in half. So that this becomes a tiny fork that I use to pick up the glue. This way I can dose very precisely on the knot. The excess glue I remove immediately with the fingers FAST. This immediately removes any shine. You don't need much glue, just enough to keep the knot in shape.
This is the largest eye needle, I have ones that are even smaller and I use them more often.
This is a tough one. If used properly, and with an applicator such as 'THIS' super-thin Ca glue can easily be applied, very sparingly, without frosting... as the frosting 'typically' occurs when too much glue is applied. That's not 'always' the case, but 'minimal' is a good general rule of thumb. Clear nail polish is another good adhesive for things like this. I learned the nail polish trick from back when I used to tie trout flies for fly fishing. Thinned PVA is good also, but 'thinned' close to water consistency is the key. As with 'all' adhesives, go easy! Too much glue will 'shine' once cured. If you 'want' a sheen, slather it on. If you 'don't' want a sheen, use just enough to get the job done. Less is usually 'more'! It really doesn't take as much glue as we typically like to 'think' it does!
clear nail polish sold at box stores works fine. its lacquer and does hold up for a long long time.
my oldest ship over 50 years old is doing just fine with both nail polish and diluted carpenters glue. back then i was trying anything i had handy.
remember, its a static model and since nothing is being toutched, there really isnt any danger even the lines i used nothing more than plain water to shape the ropes in place. just be carefull when dusting.
For fixing when working with rigging, I have been using shellac alcohol varnish for many years! The advantages over all the above clamps are that it is very easy to loosen and untangle the knot if necessary. To do this, it is enough to apply alcohol and the fixation area is freed up. Often, when restoring models, you have to pull out the weakened rigging, and fixing it with shellac allows you to do this without problems, without damaging the original. Securely fixes, for many years!
dropdown arrow
It is practically invisible on the rigging!
dropdown arrow
Cotton or poly rope?
Thank you but sometimes for the end of blocks where you mke the knot, that very edge, not the strand...snaps of if bend curved too much by the halyards. Excuse my ignorance here.. I am no expert like you guys who have build multiple models.
Starbond make a CA that comes with a pack of little nozzles that enable you to deliver just a tiny bit of glue to the desired location. They also have a non allergenic CA which is odourless. The only challenge with that one is that it only comes in thin which means you have to be extra careful to keep it from running down rigging lines as it will harden and darken them.
I've tried the nail polish and PVA approaches and have found that as much as I don't like CA, it's still the best solution in my opinion.
I use PVA diluted 1:1 with water and add a couple of drops of washing up liquid that allows glue to soak in to thread without changing colour but doesn't set solid like CA.
I use super glue but initially had problems applying it. then I bought some plastic adapters from China (Aliexpress), now I can apply it one drop at a time. Also has the advantage that if I do not use the tube for some time, I just have to cut off the tip of the spout & I am back in business. A lot less glue on the fingers too
