Many thanks Paul!Respect.
Also my respect for this decision, Allan.It has been some time since posting. I finished the framing and planking and was not happy with the results of the planking. After the planking was done I removed the hull from the former/plug, (it came away cleanly) took a deep breath, and broke it apart and dumped the entire thing in the trash. I could have settled, but at this stage of my life, I want to do the best that I can, whatever that might be, and what I had on the first attempt on this model did not come close. Sooooo, I still have the plug and will restart. HOPEFULLY it will be a good result this time.
Thanks Peter. Hours spent in a pleasurable pastime are not diminished whether it is 50 or 100 or more. I TRY to see it as an opportunity to have more fun, not a loss of any kind other than a few pieces of wood. Maybe I should have let it rot in our rainy summer and then mount it and label it the HMS Bounty jollyboat, which was rotted through. (Not to be confused with the Bounty launch used by Captain Bligh and his crew when they were set adrift by the mutineers.)Also my respect for this decision
Respect.
I get it, Allan, 100%! I design custom mechanical equipment and specialized machinery for a living. It's an R&D game where one starts with a simple concept and then begins to experience far more failures than intended successes... until 'finally' reaching the finish line. I oft times cuss like a sailor when things don't go smoothly nor work as designed/predicted, but I love it all just the same!Hours spent in a pleasurable pastime are not diminished
Your hull planking looks like poplar
I've often wondered how well it would work to take long, thin shavings, from a Kanna, and glue them up with each layer slightly alternating in grain direction and heavily weighting things down until the really thinned out glue fully cures. Might be worth a try for thin DIY plywood.I would love to find a source for plywood that thin over here.
This attempt is looking very nice, Allan. Your build has my interest because I have to make (later) for my Balder a 14-person lifeboat with lapstrake planking.In keeping with the original idea of using off the shelf materials and hand tools, power or manual, the thinnest materials can be a challenge. Birch ply in 1/64" and 1/32" works for almost all planks, be it the hull, footwaling, keelson, etc. I have the luxury of a thickness sander so normally make my own sticks of wood, but the birch aircraft ply is great.
The keelson and footwaling went in next. The risings followed. The thicknesses are shown in the scantlings list. The keelson is an inch thick and the footwaling 5/8". The breadth of the keelson is 9 but I could not find any information on the breadth of the strakes of footwaling. Looking as some cross section drawings and models I estimated the breadth. Not that there is a small gap between the strakes of footwaling. This was done so water could not accumulate on top of it where the oarsmen feet were sitting.
