I need to check on mine. I'm really not in a big hurry though, I have at least 6mos time to completion on my Le Requin or longer. That way I'll have Jan's and yours for reference builds.
Daniel --- Well Jan's for sure - mine who knows I'm the slowest builder known to "man" - but yes we will both have Jan's superb log as a greatI need to check on mine. I'm really not in a big hurry though, I have at least 6mos time to completion on my Le Requin or longer. That way I'll have Jan's and yours for reference builds.
Thanks for the Kudos, but I just bumble along, make a lot of mistakes but eventually get something done.Daniel --- Well Jan's for sure - mine who knows I'm the slowest builder known to "man" - but yes we will both have Jan's superb log as a great
guide.
Jan thanks for your great log.......
Hi, welome SOS. If you scroll down the right side of the home menu you'll see a link to Pavel's website.Hello
I am a new member and i Will like to buy a model. Kit of osberg Viking skip version 3
I saw on youtoube a model that Pavel Nikitin was building.
Wher can i buy a model kit
Best regards Sven
Okie Dokie, I've looked at the upgrade and it appears to me that the instructions show the Mast step being installed between the two #1 decks as per the kit plan. I think I have that right?????
What do you guys think???
Jan
Congrats on receiving your upgrade kit! I'm still waiting on mine, USPS alerted me that it arrived in Buffalo, NY. today...I'll probably have it in a couple of weeks.View attachment 543476
Upgrade and oars arrived yesterday afternoon. Now need to find time to work on the build.
Jan
Those frame numbers on Pavel's plans/prints has to be a mistake, it needs to go between frame 0 and frame 1 towards the bow. At least that's how I think it should work.Hmmm, how is that possible, since there is a #0 frame in between the two #1's?
I'm scratching my head trying to figure out where to start. I checked to see if there was a video to scan.Congrats on receiving your upgrade kit! I'm still waiting on mine, USPS alerted me that it arrived in Buffalo, NY. today...I'll probably have it in a couple of weeks.
I'm looking forward watching you get this installed!
Steve
Yup, head scratcher.Hmmm, how is that possible, since there is a #0 frame in between the two #1's?
I did a screen dump of one of Pavel's videos.Those frame numbers on Pavel's plans/prints has to be a mistake, it needs to go between frame 0 and frame 1 towards the bow. At least that's how I think it should work.
Steve
@RussF, my bad. You are right, I looked at the drawing wrong.
Fixed the rib labels." 0 " in the center and " 1-1" on each side.
That brings me to this quick fit
The bottom has to slot in to the " 0 " rib and the right " 1-1 " rib.
I need to remove some more material on there. I think I've got this figured out.
Jan
OK, thanks Russ. I think I understand how to proceed.I think you're still off, my friend. I think I had mentioned before that it looks like Pavel has moved the mast forward one frame as it is in the real thing.
Notice the biti numbering in the drawing. The thick biti used to be on frame 0, now it is labeled as 1 and the new frame 0 biti is a standard thin one.
I'm assuming the upgrade kit has replacements for the bitis? The new (thicker) biti 1 should go on the #1 frame that is forward of frame 0 (toward the bow).
All this will then effectively move the mast forward one frame and put it where it is supposed to go.
The upgraded mast step:
It took a bit to remove the bitis that were in the way (used vinegar to loosen the glue).
Then I couldn't figure out which direction the long portion of the mast step shpuld face, toward the bow, toward the stern???
The Pavel Plan. The mast step is in the circle is pointing toward the stern.
The modification dry fitted.
There is still a bit of snding involved before the final glue down.
Jan
I did move the mast forward to the forward frame 1, the rest of the supplied update parts fit very nicely (After char removal).If you're moving the mast forward one frame, then the mast will abut the forward frame 1 on the aft side of the frame. Place your step however that can be accomplished.
Yes Jan I have already bookmarked a few of your post too. Thanks a million!Jan,
Getting there! - Your log will be a "must go to" when I get there - Thanks for sharing your log including so many details![]()
