True story Peter. That is the alternative if I got those measurements wrongA ’below deck hidden knot’ can then provide a solution ………![]()
Beautiful work
Congrats
Thank you Gilbert and Shota. Cheers GrantBeautiful work, Grant
Precision, precision, precision. Well done, Grant.Good afternoon. This morning I did some more work on my tiller. I “rigged” the tiller cable via the tension block and tackle.
This cable will run around the drum on the ships wheel when I get to the upper deck.
Some pics:
View attachment 543465View attachment 543466View attachment 543467View attachment 543468
In the last pic you can see the block and tackle (3mm single and 3mm double configuration) tied off to the cleat.
Cheers Grant
Thank you very much Ian. To scratch build is at another level to where I am at the moment, although I do like to add and modify the kits a lot to achieve some more details. It is rather nice to have the rudder work when I pull the tiller cable. Cheers GrantPrecision, precision, precision. Well done, Grant.
I got mine to work on my Medea build (Enterprise class) but I used rope that was too thin (trying to gauge scale and got it wrong). So now it is literally hanging by a thread around the drum and I don't demonstrate it to people any more...
I wish this kit had come out when I started blundering along with my scratch build nearly 6 years ago. So much is revealed that wasn't in the plans I was able to obtain.
Baai dankie Allan. It was quite fun to put together. Cheers GrantHallo Grant,
Your steering set up is a great mini project with a beautiful result.
Lekker dag to you!
Thank you kindly Gunther....you make me blush...Hey Grant,
that's some show-off modelling ...!![]()
It just looks great. In a class of its own.
I wish I had your skills... ...Top!!
