Fair American 1:48 by Model Expo
Wow! That is a REALLY nice base! Now the pressure is on to have the ship model sitting on it be worthy...
It took 15 months to build the house I live in right now - that's 8 days in Japanese time :rolleyes:.
Thank you, Paul. The base, like the ship that will sit on it, has plenty of blemishes which I hope few other than myself will notice.
In addition to assorted bits and bobs of progress, I made good progress on the base.
The pedestals and feet aren’t attached yet. I’ll do that after I’ve drilled holes for screws and a switch and routed channels for wiring underneath.
The base itself is made from a slab of what I think is Birdseye Maple my Dad let me scrounge from his basement many years ago.
Having restored a lot of 18th and 19th c. American furniture where figured maple was very popular and iconic, your choice of figured maple is perfect for an18thc. American Revolutionary War Privateer! Even the bracket feet are period correct!
Thank you, Peter that’s very encouraging. In truth, it was a combination of what I had on hand and TLAR design.
The ship base looks very nice, I feel like it could work as is. I didn't realize you were planning to rig up some lighting for it, though. I guess I need to catch up.
For the next project, if you have any kind of CAD program they usually have hundreds of fonts from which to choose. You can size every thing perfectly and print on black or any color paper then apply to the counter. The below are a few examples. The scroll work is another thing that can be done with the computer printer. I downloaded a photo from RMG of a ship's boat and cropped it. I then inserted it into the drawing and sized it for the boat model. It was then copied as a mirror image so I had port and starboard then printed. I next trimmed the scroll work and glued to the model.
For the next project, if you have any kind of CAD program you they usually have hundreds of fonts from which to choose. You can size every thing perfectly and print on black or any color paper then apply to the counter. The below are a few examples. The scroll work is another thing that can be done with the computer printer. I downloaded a photo from RMG of a ship's boat and cropped it. I then inserted it into the drawing and sized it for the boat model. It was then copied as a mirror image so I had port and starboard then printed. I next trimmed the scroll work and glued to the model.
Thank you, Allan. I’ve used that technique on other models. I did mess around with Powerpoint to get something pretty close when I thought that a Cricut stencil might work, but I decided printing gold on paper was not going to look convincing. Not sure this does either, but at least it’s gold.
I’m sure many readers were observant enough to notice in my last update that there were no window frames in my “complete” transom, but were equally polite not to point out my glaring omission.
Mr Basswood, however, was not so polite. I can only surmise from the language he used that he was at one time a sailor prior to owning his own shipyard. He said he’s going to dock my pay for this.
Anyway, lucky to have caught it when I did because it turned out, contrary to my normal standard of precision, that the perfectly fitted window frames didn’t actually leave enough clearance for the layers of paint and varnish. Some surgery was required to get the frames to go in.o_O
Namabiir,
This looks amazing!!
It's the best! :D
In order to wire the lighting for the ship before planking the hull, but still leaving the whole thing freely accessible as the rest of the build progresses, I am going to insert electrical contacts into the keel at the points where it rests in the pedestals. The pedestals themselves have leads soldered to the bases
One will connect to the positive side of the power supply, the other the negative side. The resistor and LEDs will be in series so wiring will be simple. I drilled holes for the leads next to the holes for the mounting screws.
With everything set in place, this is how it looks. No sign of wiring and the ship doesn’t need to stay permanently attached to the base.
With the contacts installed and the ship resting in the pedestals, resistance across the whole setup is effectively nil. I’ll call it a win.
Just waiting for some resistors to show up in the mail so I can test the lighting properly.
